edelbrock 1406 slight surge
Car: '83 TA
Engine: GM Performance 350
Axle/Gears: the slowest off the line
I just swapped engines and dropped in the GM Performance 290 hp 350 available at summit and jegs. I put a bow tie 063 intake and an Edelbrock 1406 carb with a street fire dizzy and box.
I'm noticing a slight irregularity at cruise rpm. Whether I am in first, 2nd or cruising at 65 or70 in OD, I notice what I can only guess is a lean surge while cruising or holding steady at 2-3000 rpm. I backed out the adjustment screws on the front just a little and it did seem to help make it just a little better. But after adjusting the first couple "hours" on the screw there was no change. So they are pretty much back to my tuned idle settings and I will leave them there.
I am wondering if this is a lean surge that needs to be remedied with re-jetting? anyone know about this combo and if the stock jets are enough for this engine and setup? Do you know what jets I will need exactly for this setup to work correctly?
Thanks for any help.
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
Re: edelbrock 1406 slight surge
New fuel pump? A bad pump diaphragm will cause a surge while cruising.
Car: '83 TA
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Two things I would suggest.
1. Use a vacuum gauge to tune the idle mixture screws in the front.
2. Measure manifold vacuum at idle and replace the springs with a value approx 1/2 of what is measured.
Those two things can make amazing differences with edelbrock carbs
Car: '83 TA
Then I looked at the springs in the calibration kit and picked the 7" spring. I had a stock spring.
I discovered something in my test drive after that. It seemed really good for smooth idle and good power but still had that slight surge at part throttle cruise. But at one point I stopped and made an aggressive turn left while accelerating. not to completely do a donut but definitely on the edge of doing one. the car died. I then noticed the rpms were dropping a little extra low during regular turns on the ride home. I'm wondering if the floats need to be adjusted a little. I had the top off the carb the other day to try the 101 jets but didn't have a 7/16's bit to check the floats so I just figured I would check them later . what are the chances they are very far out of spec from the factory?
any other thoughts?
thanks
Thanks for the tips. I was able to set the screws to max the vacuum at about 13.5 " . I went back and forth to be sure both were set just lean enough to keep max vacuum.
any other thoughts?
thanks
any other thoughts?
thanks
Car: '83 TA
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
When you start getting into these surge issues a wideband is really going to help you out.
It might be as simple as a rod change but you need to know how lean it's really going.
This chart shows the stock items in each carb. The 1406 is slightly leaner factory than the 1405
http://www.edelbrock.com/automotive_...ors_130815.pdf
Engine: 450HP 355
Transmission: TH350
I had to make 1 rod change on my 1405 to get near perfect AFR's at cruse, WOT was pretty good out of the box. 355 with a large cam, good intake and headers.
The 1406 supposedly has the same lean issues as the 1411. According to the Edelbrock tech I spoke with when troubleshooting my 1411 there really isn't a fix for it. My issues were a lean stumble just off idle and even with the largest jets it would still go lean at WOT. Cruse was fine though.
Pac J
May 17, 2020 10:44 AM
efiguy
Sep 27, 2015 01:30 PM
Night rider327
Sep 25, 2015 04:47 AM
