holley gurus needed 2 holley 1850s pouring gas
Car: 1984 Trans Am, 1986 Fiero SE
Engine: 5.0 H.O., 2.8
Transmission: T5, M4 Muncie
Axle/Gears: 3.73 disc posi, CAVALIER AXLES!!
Ok first - the car: best I can tell it was a lg4 Camaro, but the motor was swapped, its an unknown "rebuilt" "350", performer intake, unknown heads & cam, came with a holley 1850-3 on top. bought after swap from dealer auction.
it ran ok but I noticed that the carb baseplate was wet so I looked and the primary boosters, not the secondarys, were dripping and running out the throttle shafts so I bought new primary bowl and metering block gaskets and a new 65 power valve that was in it. took the primary side apart, took the little red straw and sprayed carb cleaner in every hole in the bowl block and main body pri side. reassemble and now it POURS gas out of the primary boosters no matter what I do WTF?
F it time for a rebuild..... so I go down to my local reputable hotrod shop for a kit and end up buying a freshly rebuilt holley 1850-2 for cheap, and it does the same thing!!!. pours gas out of the boosters, squirter, and shoots out of vent tubes. This is the fourth rebuilt carb Ive bought from them and all three previous ones have worked perfect so I trust them.... I repeat - W T F ! !
so I take Mr rebuilt carb, remove the primary bowl and visually verify that the brass float moves and contacts the needle and seat and blew thru the fuel inlet and raised the float by hand and the needle & seat sealed to "shut off flow" easily, plus the needle and seat looked brand new, - I hope I explained that good enuff....
so I bought an inline mr gasket regulator adjustable from 1-6 psi installed it and it still floods......WTF!!! again
bought new fuel pump and guess what ..... still dumps gas!!!!!
when I replaced the mechanical pump it had a 2 port pump, so I bought the same.... but I noticed my 84 TA has a 3 port pump..... so I looked around and sure enuff I think I see a fuel return line that isn't connected just kinked and bent shut.... WTF!!!
WHAT TO DO NOW GUYS????
Solved......post #10
Re: holley gurus needed 2 holley 1850s pouring gas
Measure the fuel pressure.
Sounds like your regulator isn't regulating, and the carb is getting hit with WAY more FP than the needle valve can handle.
Remember, carbs work off of fuel VOLUME, not fuel PRESSURE. As long as the bowls are kept full, then it's all good. Meaning, if the bowls could be kept full at .0001 psi, then .0001 psi is all you'd "need". In reality, most of the time 3-4 psi is "enough", as long as it doesn't go away during extended high-speed operation; to assure this, 5-6 psi is usually recommended. Anything above 7 psi is just asking for trouble... specifically, the trouble you are having.
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
It's gotta be either fuel pressure or a bad needle and seat.
Ethanol causes carbs to do exactly what problems you're having. It eats the rubber gasket parts and causes the same flooding issue you're having. If you do replace the needle and seat, make sure it's made of Viton....not rubber. Viton isn't affected by ethanol.
Good luck!
Good luck!
I went and bought a cheap "dead head" Fuel pressure gauge that works with carb or efi - I cant run it "inline" until I get a proper fitting, for right now I have to disconnect the carb to use it, so I can only check pressure while cranking - so I first hook it up like so: pump -> filter -> gauge, crank it over and the needle pegs 12.....kinda high for a brand new 2 port airtex mechanical pump.....so I said F it and got a 3 port pump and reconnect the return line and get an inline adaptor for my gauge and run the line as so: pump->filter->afpr->fp gauge->carb.......and it still floods! WTF!!!
Pressure is at 5 psi on the gauge.....so I try to lower the floats and something hits me, the carb doesn't flood if the site plugs are removed.....WTF? I did nothing but remove the site plugs and the carb quit flooding..... if pressure was the cause wouldn't it puke gas out of the site plug hole? and as soon as I even place my finger over the site plug hole while cranking it floods WTF?
help
plugged vents?
oh and funny thing is I put on the Holley 570 street avenger off my TA on it and no more flood so Im thinking its the carb not pressure....the 1850 carb dumps fuel if I put the site plug in......bad metering block or bad main body allowing vacuum or pressure to empy the primary bowl thru the boosters? and if it was fuel pressure too high wouldn't the secondary boosters leak too?FAAAAK!!!!!
Car: 92 CAMARO RALLY SPORT
Engine: 383 sbc w/250 shot of nitrous
Transmission: AMERICAN POWERTRAIN- EXTREME TKX
Axle/Gears: STRANGE ENG. 12 BOLT 3:90 SPOOL
adjust the floats properly after u make sure needle and seats are good.. I like to base line my float bowel adjustment by remove said float bowel invert it and adjust until float is just above level while bowel is upside down reinstall make sure not to tear or loose o-rings final adj float level to edge of sight plug ... DONE ..
SOLVED!!!
the problem was 2 fold some cute little bugs had made a home in the primary vent tube partially blocking it.... and secondly not replacing the gas cap with a vented one pressurizing the tank making the fuel pressure run high enuff to make the carbs drip at idle which started this mess in the first place.
Well, I gotta admit, I didn't see that one coming, maybe I should have asked you to hold your carb up closer to your monitor and zoom it in. I'll take my lumps for not guessing about the bugs... my powers of ESP must be diminishing as the aliens take over...
(even though I'm often accused of being one of them)
(even though I'm often accused of being one of them) Thread Starter
HA! ur awesome sofa....yeah Holley should really update their flood troubleshooting to include pressure, floats, needle & insects...maybe even update the tuning sticky, which ill be starting for the second time tomorrow.
funny thing is this carb had been rebuilt and was sitting on a heated garage's shelf at MMG when I bought it, and looked spotless inside and out. Im gonna advise he boxes or wraps them in plastic from now on.
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
Wow! That's taking "There was a bug in the system" quite literally.
