Car cranks stops then continues to crank
Car: 1989 chevy camaro
Engine: 350 sbc
Axle/Gears: 2.77
Not sure if this is an electrical or carb question so if needed to be moved please do.
Ok heres what Ive done to the car. It was originally a '89 rs tbi that a friend swaped a 350 into. tbi never ran right due to the needing more fuel so i swaped it to carb. put a warrior intake with a standard holley carb, 600 cfm, along with a holley fuel pressure regulator with the a return. as of now it cranks stops and is a pain to crank again. Intially i thought that it was hydrolocking due to the intake fuel pump putting to much pressure on the carb pushing excess fuel. turned the key to run and looked at the carb, and theres no blow by throught the sprayers. after that i cranked it one last time just to see and it cranked until i gave it a little fuel to start it. so i figured timing. turned the distributer back and tried again and nothing changed. any ideas would be helpful. tomorrow im going to try to unplug the distributer and crank it to see if that helps.
Also: car has a brand new battery and never had an issue before with starting.
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Car cranks stops then continues to crank
You might have it 180 out. You could pull the distributor and start over. Bring #1 up to top dead center on the compression stroke. Then replace the distributor with the rotor pointing at #1 on the distributor cap and give it a try. Double check the spark plug wires for correct orientation.
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
...tomorrow im going to try to unplug the distributer and crank it to see if that helps.
When you swapped out the TBI, you MUST replaced the distributor with a non-cc distributor with vacuum advance or the car will never run right. The CC Distributor is expecting signals from the ECM which is cut off from TBI unit that you removed and it's confused. It can't control the timing properly now.
Car: 1987 Trans Am
Engine: 5.7
Axle/Gears: 373
Just pick up a HEI distributer , set your unadvanced timing to around 10° advance hook your vacuum advance hose back to the ported port on your carb and see how she runs. Then you can fine tune it from there. Mine runs best around 12.5-13° of timing. Hope this helps you. You can also run your factory tach off the HEI distributer as well.
Engine: 350 sbc
Axle/Gears: 2.77
Thanks for all the help. It was indeed the timing. Poped the driver valve cover off just to double check i was tdc on 1. Turned out that the distributor was to far retarded and was causing it. I appreciate the advice on what it could have been.
Ghettobird52
Jul 5, 2024 11:18 PM
