Feedback Quad tools
Car: 1986 Pontiac Firebird
Engine: 383 SBC
Axle/Gears: Hawks 8.8 with 4.10’s
Feedback Quad tools
Anyone know a source to acquire these tools ? I'm looking for Thexton tools 362 and 370 so I can tune my rebuilt E4ME and get the car running again but I'm having 0 luck finding a distributor that actually HAS them. Instead I keep finding distributors with listings for the tools but nothing in stock. Help please! Also, what dwell meter do you suggest? Analog, digital, a brand that you've have used and had good experiences with? Part numbers for the tools I need from any other manufacturer besides Thexton maybe??? Thanks
Re: Feedback Quad tools
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
I kept up a search in eBay for a few months and I managed to get the tools I needed. It's definetly possible. Good luck!!
I usually just make em.
Main one you need, looks like a rod about 5/32" or so dia, with a slot in the end maybe 1/16" wide; however thick the lean stop thing is. You can measure the hole in the casting that it has to go through and make it that OD. That will work on both the lean and the rich stops, as well as the idle mixture screws; except that the IM screws have basically no "authority" at all, so I usually just set em at about 6 - 7 turns out and forget em, then do all the idle tuning with the IAB.
I built a dwell meter some years ago, maybe 30 - 35, very simple circuit really. I think you can still get "automotive" DMMs that have that function, though.
Engine: 383 SBC
I found and bought the Thexton 350 which is both the double d and the 4.5mm hex. Hope it works. Now I just need to settle on a decent dwell meter. There's a cheap, one-trick Actron meter on amazon I've been thinking about getting. I don think my DMM has the dwell function on it, unfortunately. Thanks for the help though.
UltRoadWarrior9
Sep 2, 2015 08:24 PM
