Throttle sticks after going wide open!!
Old Jan 19, 2014 | 01:25 PM
potterc32's Avatar
Car: 1985 Pontiac Firebird S/E
Engine: 350, .5 lift cam, Holly 650
Transmission: Monster Transmission 700R4-2K stall
Axle/Gears: 4th gen 10 bolt, 3.42
So I had a few a issues with my quadrajet (1985 firebird) including dieseling when shutting down, harder than normal start when cold, and throttle sticking open after going wide open throttle. I would park and the engine would rev to about 2000 rpm, and I would physically have to grab the throttle linkage and pull it closed, after that it would fine until I go wide open again.
I figured it was time for a rebuild, solved all issues except for the sticking problem. Has anyone else had a similar problem? Does anyone know what could causing the linkages to stick? I don't see anything binding, it's as if the throttle spring is not pulling it closed hard enough.
Old Jan 19, 2014 | 04:45 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Disconnect the throttle and TV cables from the carb. Does it still do it?
If not, then you've got a problem with one of the cables.
If it still does, then you've got an internal carb linkage issue, or something interfering with the throttle blades. Not uncommon for a carb gasket to get in the way and hold things up.
Old Jan 21, 2014 | 06:51 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Throttle sticks after going wide open!!
Worn throttle bushings?
Prodigious
Nov 7, 2020 09:23 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
