Oil in and on carb
Old Jan 26, 2014 | 12:29 AM
John4649's Avatar
Car: 1987 camaro
Engine: 5.0
Transmission: 700-r4
Oil in and on carb
Ok my buddy's 87 firebird has q-jet carb and theirs standing oil on and in the carb my question what causes this could it be intake gaskets head gaskets iv never dealt with something like this and could use the advice
Old Jan 26, 2014 | 03:10 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Oil in and on carb
Is your pcv working ? if so its called blow bye
Old Jan 26, 2014 | 10:00 AM
John4649's Avatar
Car: 1987 camaro
Engine: 5.0
I also needed to add the carb back fired while trying to start it
Old Jan 27, 2014 | 03:26 AM
Engine: Lb9
Transmission: M20
Sounds like a timing issues, timing incorrect or chain has slipped.
Old Jan 27, 2014 | 07:53 AM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Backfire when starting is timing problems. How much oil are we talking?
Old Jan 28, 2014 | 01:42 AM
John4649's Avatar
Car: 1987 camaro
Engine: 5.0
Ok as I stated this is my buddy's car so I hadn't gotten a lot of time to look at until yesterday finally had it towed to my house the po swapped the original q-jet carb for a 1989 one the car is a 87 he managed to remove the linked to the secondary barrels on the carb so it was only running On the mains then the PVC wasnt even hooked up at all then the brake booster had no vacuum on it at all well and with my dad helping me along the way since I have the 87 camaro with same motor and trans his cars motor now starts on the first try and running beautiful oh it had about a dozen vacuum leaks
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
