Carb Concern
Car: 1988 Camaro 305TBI Iroc Base
Engine: 305 TBI
Carb Concern
I am new to the 3rd gen. I am looking to purchase a 1988 Iroc Z, but I have a concern with the engine. I had read that the 1988 model didn't come with a carb and I wanted to see if the person added a carb or did an engine swap to the car. If it is the original engine could you advise me as which one it is? Thanks!
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Carb Concern
Take the air cleaner off and take another close up of the intake/carb/tbi.
As an 88, I'm surprised it's not TPI. That said, I believe they stopped putting carbs in Camaro's in 86 so that should be a Throttle Body Injection (Fuel injection) intake. They look an awful lot like carbs with the aircleaner on.
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Re: Carb Concern
The thermostat housing doesn't have the usual sensors a carb'd car would. Base engine for an 88' IROC was the 5.0 TBI. And 1987 was the final year for carbureated F-bodies.
