How to wire Speedo on TPI to Carb swap.
Old Mar 1, 2014 | 04:08 PM
irocz253's Avatar
Car: 1987 Camaro IROC-Z Z28
Engine: Custom Vortec 350
Axle/Gears: 3.73, Auburn Pro Series diff
I have a 1987 Camaro 305 TPI vin F. I removed the ECM and the ECM wiring but I need to find out how to wire my Speedometer.
Old Mar 1, 2014 | 05:26 PM
Re: How to wire Speedo on TPI to Carb swap.
Doesn't use wires.
Old Mar 1, 2014 | 05:35 PM
irocz253's Avatar
Doesn't use wires.
When did they go to electronic speedometer? So my speedo should already be hooked up then? My speedometer on my dash will work? Are you positive?
Old Mar 1, 2014 | 05:51 PM
In the Camaro, around 89 or 90
Can't say for sure; too dark out to see right now; but if you didn't unhook it, or if you did but hooked it back up, more than likely it is
Yup
Are you positive?
Pretty sure... I have a 140 mph one out of a 87 IROC in my 83 L69 car, been working just fine for 15 yrs or so
Old Mar 13, 2014 | 09:19 PM
Donald Crafton's Avatar
I looked into the Dakota Digital interface, called them and the guy said I should be able to connect the VSS directly to the Dash Cluster, and the cluster proccesses the signal to report the speed.
CAR OBD2 SHOP
Old Mar 14, 2014 | 06:51 AM
1987 doesn't need any of that.
It uses a cable. Same as cars had been using for decades prior.
The ECM gets its speed info from a little yellow box that mounts to the back of the dash and optically "looks" at the spinning thing the cable drives.
The Dakota thing is a great solution; just, to some sort of problem that actually exists. Which it doesn't here. There IS NO problem for the OP.
And of course, 87 isn't OBD2, since OBD2 appeared in 1996. (a few in 1995... but still far from 87) So, nothing that applies to OBD2, has any connection to 87.
Jorlain
Aug 24, 2022 05:11 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
stalkier
Aug 13, 2015 12:59 PM
Sanjay
Aug 12, 2015 03:41 PM
