In-tank Electric Pump With Mechanical Pump With Return Line
Old Apr 1, 2014 | 09:25 PM
dstevenson2k's Avatar
I'm swapping my 305 TPI to a carbed 350. Instead of using the Mallory regulator, could I use the stock in-tank electric pump in conjunction with a mechanical pump with a return line, such as the Carter M6626? The in-tank pump works as a pusher and the Carter routes excess pressure through the return line.
Any problems with this solution?
Old Apr 2, 2014 | 05:23 AM
Restrorob's Avatar
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
Re: In-tank Electric Pump With Mechanical Pump With Return Line
With a return style regulator and stock in-tank pump, There's no need for a mechanical fuel pump......
Old Apr 2, 2014 | 11:08 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
A couple of members have done it. I don't see any particular problem with it. One concern that was raised is should the mechanical pump diaphragm fail, the electric pump will push fuel into the engine oil.
Old Apr 3, 2014 | 12:51 AM
Nvm found my own answer. Search is awesome!
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
theshackle
Mar 5, 2017 06:37 PM
wayshegoes
Aug 17, 2015 12:00 PM
armybyrd
Aug 10, 2015 09:23 PM
Kaweh
Aug 9, 2015 02:54 PM
