Fuel sending unit
Fuel sending unit
Done tons of researching and cant seem to find original fuel sending unit for 82 trans am where can I find one?? Mine is corroded and electric wires arent in the best shape, PLEASE HELP!
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Fuel sending unit
Try
rcar7395
John in ri
Bethscamaro
kurfbird
Tuned performance
JC Whitney may have it in Spectra brand name. Dont know the quality but they used to have them.
( edit )
PM sent.
Disregard the
M
In second line...
rcar7395
John in ri
Bethscamaro
kurfbird
Tuned performance
( edit )
PM sent.
Disregard the
M
In second line...
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
As far as I know nobody is making a carb sending unit. Below is a picture I took when I converted mine to the EFI sending unit from spectra.
You can use an EFI unit on a carb but you would have to extend the main line and put a sock on the end since it is designed to have the pump be in there with the sock. You would also have to modify the external connections as the EFI unit has high pressure connections instead of the simple barbed end the carb unit has.
Hope that helps.
Hope that helps.
Ghettobird52
Jul 5, 2024 11:18 PM
ambainb
Apr 25, 2016 09:21 PM
