fuel pressure regulator
Old Apr 13, 2014 | 12:06 AM
powerdreams's Avatar
Car: 1987 camaro
Engine: 5.7 vortec
Hey all, Im Running a carbed 5.7.
My Buddy has a adjustable fuel pressure regulator he's selling for cheap. I'd like to get it but I'm not sure its a unit to be used with a carb.
He said its universal. And has a barb on the bottom (fuel return?) a barb on the left and the right (fuel in/fuel out?) Which all makes sense but then there is a barb on the back of it. He said its vacuum. Its brand new in the bag/box and came with a rubber vacuum hose. Do fpr's need vac? Can I use this regulator?
Old Apr 13, 2014 | 12:53 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: fuel pressure regulator
The vacuum port is not needed unless you need to increase fuel pressure in certain situations, such as full throttle when running a turbo. If your not using a turbo or supercharger, just leave it disconnected. You need to make sure it has a return port, and that it will regulate the fuel pressure down to the 5-6 psi a carb needs. If you can post the part number or brand and model number, that would help. Otherwise it's just a guess as to whether or not it will work.
Old Apr 13, 2014 | 12:58 AM
Car: 1987 camaro
Engine: 5.7 vortec
Part number I can't tell u I'm pretty sure its a eBay special. But the brand is mp2 not that that helps. If the gauge that is installed on it from the factory has low psi (1-10) would it be safe to say that I'm good to use it?
Old Apr 13, 2014 | 07:03 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
If you're sure the gauge was installed from the manufacturer, it should be fine. Some pics would be helpful if you can.
Old Apr 13, 2014 | 07:12 PM
Car: 1987 camaro
Engine: 5.7 vortec
I figured it out today. It is for fuel injection. Thanks for the help
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
