Stock Throttle Stop Screw Setting
Old Apr 21, 2014 | 09:41 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If the secondary throttle stop screw has been removed on a Holley 4160, what's the procedure for putting it back to the stock setting?
JamesC
Old Apr 22, 2014 | 05:55 AM
Re: Stock Throttle Stop Screw Setting
Rotate clockwise.
Why would you want to put it back there? It's wrong, ALWAYS, and needs adjustment to tune it to the engine, just like the pri one is when you pull a carb out of the box; that's why it needs to be adjusted to coordinate with the pri setting to set the correct relationship between the pri throttle blades and the idle transfer slots.
At what point in the transfer slot process are you?
Old Apr 22, 2014 | 06:32 AM
JamesC's Avatar
Been tinkering for a while. An idea has suddenly occurred to me, one that I'll try today. May cure my car's ills. We'll see.
BTW, the jets/PV are in place and that part of the tune seems terrific.
JamesC
Old Apr 22, 2014 | 12:04 PM
JamesC's Avatar
Ok, I must have things pretty close, but I still have a slight hesitation/bog at low speed.
JamesC
Old Apr 22, 2014 | 01:54 PM
JamesC's Avatar
A bit more tune and the bog seems to be gone. I went to the road where I tune, went around a roundabout in second and got on it. Screeching tires, a little sideways movement—dang near soiled my tidy whities. I'm going to live with the current tune for a coupe of days and see....
JamesC
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
italiano67
Dec 11, 2016 09:21 AM
camaro71633
Sep 1, 2015 10:24 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
