Quick fuel guage question
Old Apr 23, 2014 | 06:52 PM
tmork454's Avatar
Car: '87 Camaro
I just used a multi meter on the one wire coming out of the gas tank (because my car was swapped to a carb 350 by the last owner) and found that it was reading 69.5 ohms. When i measured the voltage on the pink wire coming from the dash it measured 5 volts. I thought the gas tanks operated on about 3 volts. If thats true how could i lower the current?
Old Jun 6, 2014 | 11:17 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Quick fuel guage question
You can't. The entire car should be 12v on power wires.
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
