rochester quad jet vac pipes
Old Jul 6, 2014 | 01:18 PM
mans1's Avatar
Car: pontiac firebird trans am 1984
Engine: 5.0 v8 H.O
Transmission: auto
Axle/Gears: 700R4 auto overdrive
hi has anyone got a pic of where the vac go from the carb as I have a pipe sucking in air with a T connecter doing nothing also the trans cooler is steaming as well are they connected if how also on the there a place on one of the carb but not on the carb itself so a pic whould really help thanks
Old Jul 6, 2014 | 06:37 PM
Damon's Avatar
Re: rochester quad jet vac pipes
Trans cooler has nothing to do with the carb. So at least you can cross that one off your list.
There is a vacuum routing diagram in one of the stickies at the top of this thread.
If you get stuck, post up a pic of the offending line/t-fitting (and where it hooks to the carb) and we'll see if we can't nail that one down for you quick.
Old Jul 7, 2014 | 12:15 PM
mans1's Avatar
Engine: 5.0 v8 H.O
Transmission: auto
hi I have taken the pics as you see by the pics I'm at a total lose I hope the pics are ok thanks
I have got more pics
Attached Thumbnails rochester quad jet vac pipes-100_6066.jpg   rochester quad jet vac pipes-100_6061.jpg   rochester quad jet vac pipes-100_6067.jpg
Old Jul 7, 2014 | 07:38 PM
Pics are largely worthless.
YOU'RE standing in front of the car; we're NOT.
Follow the diagrams. They don't lie. (speaking as someone that has posted some of those in the past) Don't fret over what a mess it is now; instead, concentrate your mental effort on making it match the diagram for your car.
Old Jul 8, 2014 | 11:13 AM
mans1's Avatar
Engine: 5.0 v8 H.O
Transmission: auto
still it runs ok sucking in air and I'm standing by the drivers fender witch diagram is
Old Jul 9, 2014 | 01:05 PM
mans1's Avatar
Engine: 5.0 v8 H.O
Transmission: auto
hi I have sorted it now it turned out to be from the sphere under the canister that connected to the cruise control I took that off put on to the T join and the other pipe into the cruise and bingo worked also the A/C now works as well so problem solved
Old Jul 9, 2014 | 02:50 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Without the vacuum reservoir attached, expect the AC to blow out of the defrost vents temporarily while under hard acceleration.
Old Jul 9, 2014 | 04:30 PM
mans1's Avatar
Engine: 5.0 v8 H.O
Transmission: auto
the reservoir is attached using the T all I have done is having read all the books just did it and it sorted the air con is working great now and it has got vac
Old Jul 9, 2014 | 08:26 PM
That's the way to go: just make the car match the diagram. Beats trying to decipher "what's there", since that could be anything (and usually is), with no rhyme or reason whatsoever. Best to forget all that and just focus on "make it right" instead of "what's wrong".
LT1Formula
Oct 8, 2015 08:34 PM
