another fitment quest.
Car: 91RS
Engine: carb'd 357 vortec
Axle/Gears: 3.42 posi
I have a 350 with edel. performer rpm intake, and a edel. 1411 carb and this is the hood I was going to use:
https://www.thirdgen.org/forums/atta...0125-00084.jpg
but it met with an unfortunate accident. so now I have to either buy a $500 hood (ss or cowl). or I have to find a air cleaner that will fit under the stock (perfectly good) hood. a 14in drop base hits the dizzy and the fuel line inlet will have to have a 90degree 3/8npt to hose barb put in. help please!!!! oh and I'm using oem rubber motor mounts.
Car: 91RS
Re: another fitment quest.
maybe this will help https://www.youtube.com/watch?v=wFTX...ature=youtu.be
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
what dist/cap are you using? i have a edelbrock 14x3 drop base on mine, mallory 85 has a big cap and it still clears by a hair. cant help with the fuel, i have a DP
Car: 91RS
Big style hei cap. I read somewhere that ppl had success with mr gasket 4339 with just a little mod. this is the one I bought at first http://www.summitracing.com/parts/KYS-100-68826B
Car: 87 bird
Axle/Gears: 4.10
i think this is mine, they have one that has more drop but then in the notes it says you have to add a spacer so its less drop over all, doesnt make any sense. this one fits edelbrock and 4150 carbs without messing with it
http://www.summitracing.com/parts/edl-1221/overview/
not 100 percent sure because i got a whole edelbrock dress up kit at a local speed shop. that seems the same though
Car: 91RS
thx, but does it clear the dizzy? and does it work with the straight inlet hose barb connection?
Car: 87 bird
Axle/Gears: 4.10
It does clear, I didnt have to do anything like dent it or anything
notes for 1221 .6inch drop air cleaner;
Designed to fit all Edelbrock squarebore and Q-jet carburetors.
1207- notes for the 1inch drop one;
When using this air cleaner with Edelbrock squarebore electric choke carburetors a 3/4 in. spacer must be used. When using this air cleaner with Edelbrock manual choke carburetors a banjo style fuel inlet fitting must used. Click the Suggested Parts tab for more information.
Car: 91RS
jw so far so good I believe it will work when I get off work I will try to put the hood on and close it. I got the 1221
Car: 87 bird
Axle/Gears: 4.10
should take a pic and post it, seems like a pretty common question
Car: 91RS
nope jw, it doesn't fit the hood is of course riding on top of the filter lid. tilting back and forth like a see-saw. does anybody else have a combination close to this and making it work with the stock hood? or am I the only trying to?
350 engine, performer rpm vortec intake, edelbrock 1411 carb,
Car: 91RS
just thught about a 2in element or will this starve the carb for air?
Car: 87 bird
Axle/Gears: 4.10
just saw that you had vortec heads and intake, that stuff is different. sorry
Car: 91RS
I didn't want to use this hood because it needed a paint job and a few dents from being accidentally ran over (is good to pay attention) but I have to admit It fits like a glove.
Car: 91RS
dagblasted!!!! I didn't know that the shift cable for the v6 is shorter than for the v8. do they make an adapter?
Car: 91RS
1221 air cleaner base did clear this hood with 2.5in filter but b/c of daage to hood the hood wont lay like it is supposed to, so I have to go with stock for now but If I git rid of wing nut,threaded rod and git reg. bolt go into the carb for the air cleaner and git the 1480a filter it will fit like a glove thx fellas.
Chad Speier
Sep 24, 2015 12:32 PM
86White_T/A305
Sep 21, 2015 05:28 PM
