carb to hood clearance
Old Jan 25, 2014 | 05:08 PM
camaro211z28's Avatar
Car: 92 camaro RS
Engine: vortec 350/396
I have a 92 rs. Just built a 350 for it. Im looking at I takes right now and was wondering if anyone has a air gap I take with edelbrock carb and if that will clear factory hood. Id also like to put a air cleaner on it. It will most likely hace to be a drop base. But if anybody has ran into clearance problems with an air gap intake please let me know
Old Jan 25, 2014 | 08:56 PM
my3rd's Avatar
Car: 1991 firebird XS
Engine: 5.7 tbi
Transmission: stock 700r4
Axle/Gears: 9 bolt 3.23
Re: carb to hood clearance
I don't think it will close with the air gap, I know I just did the carb swap yesterday and I would have been able to close my hood...I have a performer rpm, holley 650 double pumper and with a 3 in filter and drop base it soul
Would be impossible for my stock hood to clear. (Luckily I am running a3in rise ram air hood)
Old Jan 27, 2014 | 10:25 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The carb mount does not sit any higher on an "Air Gap" intake than on the same type non-"Air Gap" intake. Meaning the carb on a Performer Air Gap won't be any higher than on a Performer manifold; or a carb on a Performer RPM Air Gap won't sit any higher than on a Performer RPM.
As long as you don't use an adapter or spacer, and do use a drop base air cleaner, the hood will close.
Old Jan 27, 2014 | 10:30 AM
stroken85z's Avatar
Car: 1985 Z28/1981 Z28
Engine: 85 383 stroker/81 350
Transmission: 85 fortes tko 600 /81 turbo 350
Axle/Gears: G P ford 9" in proces
i run an airgap with a drop base and a 3in air cleaner with a thick carb gaskt and it closes , its pretty damn tight but it does work. i have had a holley and an edel no problems with eitheir one. my hood is the iroc style if that matters
Old Jan 28, 2014 | 12:17 AM
JTV's Avatar
JTV
Car: 1987 Pontiac Firebird
Engine: stock LG4 305 ccc
Transmission: r700
Axle/Gears: 2.73 (turd)
Good thread. Im planning out a motor swap in my 87 firebird and was wondering if a airgap with a AED mod holly choke horn removed holly would fit under my stock power buldge hood? And base dropped air filter
Old Jan 28, 2014 | 07:24 AM
bestracing's Avatar
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
When I first modified my 86 T/A, LG4, I installed an old Performer manifold with a Holley carb and I modified the stock air cleaner to fit over the Holley fuel bowls and it fit but it was close. Later I had installed a Performer RPM and then in the stock air cleaner would hit the hood so I had to get a drop base air cleaner.
Old Jun 30, 2014 | 06:52 AM
budget builder's Avatar
Car: 91RS
Engine: carb'd 357 vortec
Axle/Gears: 3.42 posi
hey do u have any part numbers I am having the same problem I have a 350, performer rpm, and edelbrock 1411 i bought a edelbrock 1221 but it does not clear.
Old Jun 30, 2014 | 07:20 AM
bestracing's Avatar
Engine: Broke - 350
I would think the Edlebrock 1221 or 1207 would fit. Here's a quick search link on Summit
http://www.summitracing.com/search/d...rder=Ascending
Old Jul 14, 2014 | 06:56 AM
Car: 91RS
hey thx, I had to get a mr. gasket 1480a and that works like a charm
Old Jul 14, 2014 | 05:15 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
I would like to find a drop base that I can use with my cowl-induction top.
Old Jul 15, 2014 | 06:49 AM
bestracing's Avatar
Engine: Broke - 350
Check out this thread
https://www.thirdgen.org/forums/carb...b-sealing.html
Old Jul 15, 2014 | 08:52 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Originally Posted by bestracing
Very informative, but not sure it's what I'm looking for.
I need one for a stock bird "Power bulge hood", that's drop base enough to allow me to fit a performer RPM or RPM Air Gap intake but is still sealed like the factory ones is so I can use my factory style top.
Frozer!!!
Jan 19, 2024 04:55 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
New2Chevy
Sep 28, 2015 12:35 AM
SlowAZ28
Sep 2, 2015 05:19 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
