Quick Fix
Old Aug 30, 2014 | 09:16 AM
mr z28's Avatar
Car: 74 Nova prostreet 87 Iroc Z28
Engine: 427 671 blower 350 Built
Transmission: 700R4 both
Axle/Gears: Dana 60 an a 323 posi.
Quick Fix
Can someone tell me how to fix the sending unit on a 87 iroc it went bad an doesn't register on gage right what can I do to fix it Thanks.
Old Aug 30, 2014 | 09:52 AM
gearhead141's Avatar
Car: 1985 Trans Am
Engine: LG4
Axle/Gears: 3.08
Re: Quick Fix
What sending unit are you referring to; the fuel level? You may get more responses under "Electronics".
Old Aug 30, 2014 | 12:05 PM
Zane M's Avatar
Car: 1991 GTA
Engine: LB9
Re: Quick Fix
Short version: Drop tank. Install new sending unit. Reinstall tank.
You can verify it isn't a problem with the wiring or guage by unplugging the connector, then grounding the two pins together on the side that is running to the guage. If the guage moves, your wiring and guage are ok, and you can proceed with the sending unit.
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
92firebirdguy
Sep 1, 2016 07:53 AM
Twin_Turbo
Mar 14, 2016 10:10 PM
mackjar66
Sep 14, 2015 01:17 PM
