Fuel pump issues???
Old Nov 2, 2014 | 12:01 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Fuel pump issues???
Got a healthy carbed vortec 350 motor in an 89 rs, that did have a 305 TBI in it..We are using the stock fuel pump, and delivery system up to the firewall, it then goes into a regulator with return...FP at idle is between 7, and 8 pounds...It seems we are running out of fuel in hi gear at the big end of the track...Does anyone know what the flow rate is for the stock setup, and can someone suggest a good drop in replacement??? I have done a bit of searching, but no luck...Thanks...Tom
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
