2 quick questions
Car: 1983, 1986, 2001 Trans Am
Engine: 305 cfi, 350 carb, LS1
Transmission: 700,Edge 2800 th350,Edge 3400 4L60E
Axle/Gears: 9 Bolt 3.27 Borg-Warner, built 3.73
2 quick questions
Probably answered a 1,000 times jus need a few answers fast my 86 bird originally came with a 305 tpi and I am in the process of doing a 350 carb swap the 350 was out of a 94 Silverado and TBI. Soooooooo pretty much my question I'm swapping fro. Vbelt to serp and the original alt uses 2 wires and the new alt only uses 1 jus wondering wat to do there. 1 wire goes to the starter the other I haven't traced jus wondering wat to do there.
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: 2 quick questions
Ive had a few people tell me there is a pigtail for the conversion if anyone has that part number would appreciate it....
Car: 1984 Trans Am
I have it, but I didn't look at it last night. Do a search, trust me, its there. That's where I got my info on the pigtail. I'll look tonight and see if there is a P/N on it when I get home from work tonight.
Thanks a lot man I appreciate it my schedule right now is really tight so I barely have time to get on and respond here. I've done a couple searches and only found 1 site that carries it but was hoping that kragen has it if not I might see if Brian tunedperformance can make me one.
I have 1 more question when I pulled out the 165 harness it took out my oil pressure wire to the gauge and was wondering how that would be set up.
[IMG]
[/IMG] Right before I left work is wat the motor looks like I'm a complete newb to carbs been dealing with this tpi and ls since I was 17. Pretty much jus a 350 TBI motor out of a 94 Silverado 4x4 converted to carb. 2101performer with a 600cfm summit carb goin to run the stock pump with the Mallory regulator jus need the fittings and where I wanna mount it. Should be good to go next week I'm hoping. If anyone has any pointers or suggestions I'm all ears.
[/IMG] Right before I left work is wat the motor looks like I'm a complete newb to carbs been dealing with this tpi and ls since I was 17. Pretty much jus a 350 TBI motor out of a 94 Silverado 4x4 converted to carb. 2101performer with a 600cfm summit carb goin to run the stock pump with the Mallory regulator jus need the fittings and where I wanna mount it. Should be good to go next week I'm hoping. If anyone has any pointers or suggestions I'm all ears. Last edited by 86firebirdta; Nov 5, 2014 at 01:57 PM.
Got the alt pigtail thanks for your help on that. If anyone can help me with the oil pressure gauge would appreciate that too.
