Switching booster vacuum to manifold
Old Nov 11, 2014 | 05:26 PM
robg91z's Avatar
Car: 1991 Camaro Z28
Engine: 350ci TPI
Transmission: built 700r4
Axle/Gears: 4th gen rear end
Ive been having problems with my brake booster vacuum. Already have a vacuum canister and improved but not enough. I currently have the vacuum line connected to the back of the carb and want to switch it over to the intake manifold since ive heard good results. I am running a ulta holley double pumper carb with rpm air gap intake. I have no clearance to install the 90 degree fitting. What size of carb spacer would i need in order to have clearance for the fitting? I am using stock hood so that can be another clearance issue. Thanks in advance
Old Nov 11, 2014 | 08:45 PM
Damon's Avatar
Re: Switching booster vacuum to manifold
They make a low-profile 90* fitting for such applications.
Let me guess. Holley carb on an Edelbrock intake, right?
For future reference, Weiand has direct competitors to every Edelbrock intake (they work just as well or better) and they put the manifold vacuum fitting in a location where it doesn't interfere with the rear fuel bowl of a Holley carb.
Edelbrock intentionally puts the port where it will interfere with the installation of a Holley-style carb. Why? They want you to use an EDELBROCK carb, of course!
Old Nov 11, 2014 | 08:54 PM
robg91z's Avatar
Engine: 350ci TPI
Haha yup holley carb on a edelbrock. Well i bought a fitting from an auto parts store which is from spectre i bought it to give it a shot and see if it will work. Its a 90 degree. But im not sure how big of a carb spacer i need in order to make this work
Old Nov 12, 2014 | 09:33 PM
Damon's Avatar
If you get a true "low prifile" 90* fitting you shouldn't need more than a thick carb-to-manifold gasket.
Old Nov 12, 2014 | 10:21 PM
robg91z's Avatar
Engine: 350ci TPI
Does anyone sell a low profile fitting? Are you talking about the carb adapter plates?
Old Nov 12, 2014 | 11:13 PM
Night rider327's Avatar
Car: 1988 Camaro
http://www.summitracing.com/parts/edl-8096 There you go
This one might work too http://www.summitracing.com/parts/prs-1043/overview/
I don't think you will see any benefit from going from back of carb to intake. I tried that one mine and it didn't help a bit. I was also using a vac can at that point too. I ended up just swapping to manual brakes.
Oh and you can just put a pipe plug in that hole and drill you a new hole and tap it with 3/8 NPT tap anywhere on the runner
db057
Sep 4, 2015 07:57 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
cstrobel65
Aug 15, 2015 10:19 AM
