What do I do with wiring harness after CARB swap
Old Oct 27, 2015 | 07:40 AM
  #51
Amillionoh7's Avatar
Car: 92 RS
Engine: Sbc With h/c/i/e holly4150
Transmission: 700r
Re: What do I do with wiring harness after CARB swap
Originally Posted by snakeshooter
Quick question about using manual fuel pump. Did you have to do anything to the stock fuel pump or fuel lines. Other than unplugging the wires to it and hooking the fuel line to the pump?
I removed stock in tank fuel pump and replaced it with a piece of metal fuel line with a sock on the end. Left the stock fuel lines to front of engine then ran new line to mech pump.
Old Dec 2, 2016 | 12:35 AM
  #52
AdarianZ28/IROC's Avatar
Car: 89 Camaro IrocZ
Engine: 400 6.6l V8
Transmission: Turbo350
Axle/Gears: 3.0.7
Hello I just completely cut up a spare harness that I had due to the fact that it was set for electronic fuel injection. Does anyone get the Socket half/Pin half? Or if someone can make a youtube video on making a C100 Harness for carb set up from scratch would be awesome.
Old Dec 4, 2016 | 08:38 AM
  #53
makaveli09's Avatar
Engine: 350sbc
Transmission: TH700R4
There is plug that comes from the drivers side. With all gauges and starter,alternator wires. Trace the wires from there. And you should be good.
Old May 17, 2021 | 07:15 PM
  #54
Chip1977's Avatar
Car: 1986 Z28
Coming in late. I am doing a TPI to carb swap. I want to remove ecm harness from under hood. I understand that the fuel pump is powered by ecm. What so I have to keep to make it function. I already have a pro billet fuel pressure regulator with bypass so I can use factory pump. Thanks
Old May 19, 2021 | 08:35 AM
  #55
Twin_Turbo's Avatar
Best way. An ign switched time relay NC gor that pump prime parallel wired through the oil pressure sender/switch to feed pump w oil pressure
Old May 19, 2021 | 11:19 AM
  #56
Chip1977's Avatar
Car: 1986 Z28
can you break this down a little more for me please. Thanks
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
armybyrd
Dec 5, 2015 09:22 AM
Reddeath210
Oct 6, 2015 08:20 AM
cstrobel65
Aug 15, 2015 10:19 AM
