Holley 12-803 mount location
Old Mar 10, 2015 | 10:45 AM
fteufert's Avatar
Car: 1982 T/A
Engine: 1973 400 Chevy
Transmission: 4 Speed Borg Warner
Axle/Gears: 3:23
I have a 400 sb in my 82 Trans Am, with a Carter M6626 mechanical pump feeding an Edelbrock 1407 carburetor. I will be adding a pressure gauge right after the regulator.
I am adding the regulator since the Edelbrocks like the lower fuel pressure.
Can I mount the Holley regulator on the intake, or should I mount it on the inner fender?
Yes my car runs fairly hot on an average day.
Either way, I will use steel fuel line for the majority of the runs, with only short rubber fuel line as required.
Also, any hints on a good fuel line from the pump to the carb? The outlet on the fuel pump is right near the lower radiator hose.
Thanks guys
Old Mar 11, 2015 | 09:23 AM
Night rider327's Avatar
Car: 1988 Camaro
Re: Holley 12-803 mount location
On intake or inner fender will work fine. I have mine on the inner fender, mostly due to the fact I like to tinker and change things alot so less on the intake/in the way the better. With it on the inner fender/strut tower it's easier to remove intake.
For fuel line, I use alum. hard line, with short lengths of rubber and clamps to join it together.
Here is a few pics of mine.
https://www.thirdgen.org/forums/atta...icture-219.jpg
https://www.thirdgen.org/forums/atta...t-dscf3430.jpg
https://www.thirdgen.org/forums/atta...icture-430.jpg
https://www.thirdgen.org/forums/atta...icture-431.jpg
https://www.thirdgen.org/forums/atta...3-dscf3548.jpg
https://www.thirdgen.org/forums/atta...c-dscf3539.jpg
https://www.thirdgen.org/forums/atta...c-dscf3536.jpg
Old Mar 11, 2015 | 12:18 PM
fteufert's Avatar
Car: 1982 T/A
Axle/Gears: 3:23
Thanks, it looks good. I may just do the same.
Frozer!!!
Jan 19, 2024 04:55 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
355tpipickup
Aug 19, 2015 10:02 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
