Best pick of intake manifold?
Old May 10, 2015 | 12:02 PM
Dracoheart's Avatar
Car: 1992 Camaro RS
Engine: 350 SBC Vortec
I have finally installed a 350 Vortec out of a 96 Suburban and now i am in search of an intake for it. I already have an Edelbrock 1407 w/ electric choke conversion. i have asked a couple of engine builders and some say to go with the basic EPS for the vortec heads and another told me to go with a RPM Air Gap. I am also trying to fit this under my 92 flat top hood but i have future plans for a sunoco hood from Hawks. The car will mostly be a daily driver with a once a month road race. Not shooting for crazy horsepower right now.
Any other suggestions are welcome.
Old May 10, 2015 | 12:21 PM
Damon's Avatar
Re: Best pick of intake manifold?
The EPS is a very good manifold for a stock-ish Vortec (and will fit under your hood). Weiand also makes a manifold series called the Street Warrior that's their direct competitor to the EPS. (FYI: Summit house brand manifolds are re-badged Weiands with Summit's logo stamped on top and a few bucks knocked off the price.)
The Performer RPM Vortec is also a good manifold, though probably a bit of overkill for your stock long block. Hood clearance with a factory flat hood will be tight in the extreme. Sure, the carb will fit, but it doesn't leave much room for an air cleaner so you end up playing a lot of what I call "air cleaner games".
If you want to run a QJet carb, the ONLY manifold that will work is the Performer Qjet Vortec.
Old May 10, 2015 | 01:20 PM
Dracoheart's Avatar
Car: 1992 Camaro RS
I already have the Edelbrock 1407 which is a regular square bore. And that is what i was thinking about the RPM Air-Gap. I had an idea of finding a ultra low profile single inlet air horn and connect it to a factory TPI twin filter intake but then i found out the TPI intake and air horn would run me about $500 when it was all done so i scrapped that idea.
Old May 11, 2015 | 10:13 AM
Blk91Firebird's Avatar
Car: 91 Firebird, 89 Bird, 86 Bird
Engine: None, 5.7, 5.0 L.O.
Transmission: None, T5, Thm 350
Axle/Gears: 3.23, 02' 3.43 rear disc, ???
My Brother went with the weiand intake for vortec heads with the same carb and he loved it and I dont think he had any hood clearance issues but he was running a short small filter but that was a preference not a requirement. Had to buy a different throttle and return spring bracket but I think you will run into that with any vortec intake since the bolts are at a different angle
Im running a 3" tall 14" diameter filter on my performer RPM intake with a 1405 edelbrock and you cant fit a piece of paper between the carb stud and the hood so its real tight. Given thats not with vortec heads but the Edelbrock website lists the Both the Vortec and the older style performer RPM manifolds as having a carb pad height of 4.72"
deracer
Apr 11, 2016 12:04 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
theurge
Aug 21, 2015 12:46 PM
Jake_92RS
Aug 11, 2015 10:39 AM
