Fuel pump relay
Old Mar 18, 2010 | 02:01 PM
BahN's Avatar
Car: 1987 Trans AM
Engine: Twin Turbo 6.0 LS2
Fuel pump relay
Hey guys, quick one. I have an 87 LG4 that had the in-tank pump. Where's the relay for this pump? I searched and everyones saying near the brake booster but im not seeing it. Can someone give me some better instructions or a picture? thanks!
Old Mar 18, 2010 | 06:13 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: Fuel pump relay
Mine is near the brake booster, it has a rubber-like mount, that holds it to the relay bar.
Old Mar 23, 2010 | 10:15 PM
bradwulf20's Avatar
Car: 91 camaro RS
Engine: 305 carbeurated
Re: Fuel pump relay
mine on my 91 rs camaro is on the firewall there are three of them right next to brake booster it is the one farthest to the left if you are looking at the windshield there is a red wire with a black connector for manualy priming the pump that is coming from this relay
Old Mar 23, 2010 | 10:24 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: Fuel pump relay
Did your car come with a carburetor from the factory?
Old Mar 23, 2010 | 10:33 PM
BahN's Avatar
Car: 1987 Trans AM
Re: Fuel pump relay
yes, but it came with a pusher pump in the tank to eliminate vapor lock
Old Mar 23, 2010 | 11:11 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
Re: Fuel pump relay
yeah, I thought though that it only covered 82-84 models... was your car a 305? My car came with carb and is a 305, however I don't know if it has the intank fuel pump... I am going to do a TPI conversion and if I already have the baffle inside the tank then I don't need to purchase a new FI tank...
Old Mar 23, 2010 | 11:16 PM
BahN's Avatar
Car: 1987 Trans AM
Re: Fuel pump relay
car was a 305 LG4, 1987 its now an LT1. All the tanks are the same if i recall. My car was suppose to have rubber lines, but it has metal lines all the way. Only mod i had to do to the fuel system was pull the pusher pump out, put in an FI one which is taller, cut the feed tube a little to fit the taller pump, and i was good to go. no need to buy a whole new sender unit.
Old Mar 24, 2010 | 01:15 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
yeah, I thought though that it only covered 82-84 models... was your car a 305? My car came with carb and is a 305, however I don't know if it has the intank fuel pump....
As is oft discussed here, the '87 LG4's came with a pusher pump in the tank. late-'83-ish through '85 (reports vary) L69's also had the pusher pump. There was a dealer-installed vapor lock kit available to resolve vapor lock complaints that included a pusher pump, but they weren't very common. My '86 donor car had a thermostat-controlled blower that cooled down the carb when the engine was hot and not running, apparently part of the dealer vapor lock kit, but the donor car didn't have the pusher pump.
Old Mar 24, 2010 | 01:37 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
Re: Fuel pump relay
So then the only way to verify if my car has a pusher pump is to drop the tank or what? What would I be looking for, if it has the pusher pump, then I wouldn't need a new tank for my FI conversion, right? Just buy a Walbro and I'm set? I was going to ask if there was an RPO code as well, but from memory I was never able to find a label...
Old Mar 24, 2010 | 01:54 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Fuel pump relay
If you have an '87 it should also have the two-wire oil pressure switch in-line with the fuel pump relay, tee'd off the brass fitting that also holds the oil pressure sending unit. If it's got the switch it's got (or had) the pump. Reverse may not be the case.
Old Mar 24, 2010 | 06:05 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
Re: Fuel pump relay
So if this is the case, then a fuel injection pump will work in this tank, right? I won't have to keep the tank at least half full, so I don't run out of gas?
having the following, pretty much ensures that I have an intank fuel pump, right?
so the bottom one (big one on T) is the fuel pressure /oil pressure switch... I could run this off a toggle switch right?
The top one is the oil pressure switch connected to the gauge?
Old Mar 25, 2010 | 02:39 AM
KNBlazer's Avatar
Engine: 5.1 4bbl
Re: Fuel pump relay
tic-toc
Old Mar 25, 2010 | 07:48 AM
naf's Avatar
naf
Re: Fuel pump relay
Nah, other way around. The small one should have a two-wire connector that controls the fuel pump relay-you'll have to pull out a wiring diagram to see how it controls it-I can't remember if it's part of the engine or ECM harness.
The larger unit is the OPSU with a single wire connector that controls the dash guage.
Old May 13, 2015 | 05:24 AM
thebandit50187's Avatar
Car: 92 Trans Am, 87 Formula
Engine: 305 soon to be TBI, 91 305 TPI swap
Axle/Gears: 10 bolt
Re: Fuel pump relay
im converting my 87 LG4 to TPI and i wanna know where my relay is because i dont see it on the firewall, but i cut a trap door for the fuel pump and i do see a relay screwed in behind the rear seat... i was thinking it could be the fuel pump relay in the next few days ill come back with updates... i think i have to bypass VATS before my fuel pump can get power any ways. TO BE CONTINUED........
Old May 13, 2015 | 01:46 PM
Blk91Firebird's Avatar
Car: 91 Firebird, 89 Bird, 86 Bird
Engine: None, 5.7, 5.0 L.O.
Transmission: None, T5, Thm 350
Axle/Gears: 3.23, 02' 3.43 rear disc, ???
Re: Fuel pump relay
I'm pretty sure thats just the connector for the wires going to the sending unit and pump, not a relay
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Kaweh
Aug 9, 2015 02:54 PM
