in dash fuel pressure gauge?
Old Nov 13, 2015 | 11:21 PM
stalkier's Avatar
Engine: 5.7ltr
Transmission: 700r4 with shiftkit
Axle/Gears: LS 4.11
Ok this might be a stupid thing to ask but please be kind. I am wondering if there is a way to safely monitor fuel pressure from inside the vehicle such as a sending unit and gauge for a non-ECU Trans Am 5.7. Vehicle is using an edlebrock 600CFM carb and mechanical pump. I would like to be able to monitor fuel pressure as I am driving.
Old Nov 14, 2015 | 12:00 AM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
Re: in dash fuel pressure gauge?
You basically answered your own question, you need a pressure transducer and a compatible gauge to read the transducers output. NEVER run fuel line into the cockpit for a gauge. I don't think an oil pressure switch would be good as it is designed for higher pressures but probably not accurate enough under 10 psi. Might be good for a TPI setup, but again, how accurate is an oil pressure gauge?
Old Nov 14, 2015 | 12:45 AM
stalkier's Avatar
Engine: 5.7ltr
Axle/Gears: LS 4.11
Correct sir. I would never run fuel line into the cockpit for any reason. I was simply seeing if someone knew of a safe way to read pressure while driving. There has to be a way of doing it.
Old Nov 14, 2015 | 01:19 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
They make gauges with a diaphragm isolator. The section that goes to the cluster is filled with something similar to antifreeze iirc. They are usually much more expensive as well. Otherwise people mount the gauge on the hood and that is more often on track cars.
http://www.jegs.com/i/Auto+Meter/105...FYRDaQoduBkFyg
Scroll down to find more details on both gauges.
http://www.americanmuscle.com/autome...l-install.html
GeneralIesrussi
Jan 22, 2018 01:19 AM
3rdGenBirdOwner
Mar 3, 2016 09:03 PM
punkmaster98
Exterior Parts for Sale
Dec 3, 2015 11:56 PM
Necron
Nov 7, 2015 07:12 AM
David Adamson
Oct 23, 2015 05:10 PM
