Air filter base
Old Jan 10, 2016 | 06:06 PM
Paulie84vert's Avatar
Air filter base
I just had this air filter housing made for my Trans am can anybody point me in the right direction for a base that will clear everything under the hood? still have the stock q jet carb
Old Jan 12, 2016 | 05:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: Air filter base
How were you planning on fastening it down?
If you use the normal carb stud, any standard 14" drop base air cleaner would work (assuming your filter is 14"). You'll have to buy the entire air cleaner, most likely.
Old Jan 14, 2016 | 02:55 PM
Re: Air filter base
I'm going to drill a center hole on it and use the stock carb stud. It's 14inch. I will look into the drop bases thanks!
gta_knight
Jan 26, 2016 12:29 PM
87350gtanj
Jan 18, 2016 11:57 PM
1701-Z
Jan 8, 2016 03:17 AM
xbazzarex
Jan 5, 2016 08:01 PM
