High idle sticking open
Old Jan 25, 2016 | 12:55 PM
Ce84q8's Avatar
Car: 1984 Camaro
Engine: V6 2.8
Hello.
Recently changed my alternator and have had issues with the car idling high. I was trying to adjust the idle speed earlier and noticed the kick down for the high idle was sticking open every time the gas was touched. Choke seemed a little open while cold.
The little lever needed a little force to pull back not really loose like it should be. I'm thinking I need to adjust the choke first and see where it takes me from there? I wanted to know what your thoughts were.
2BBl. Rochester carb.
Old Feb 6, 2016 | 07:13 PM
85Maroon's Avatar
Car: 1985 Camaro Z28
Engine: LG4
Transmission: 3-Speed Automatic with Overdrive
Re: High idle sticking open
Originally Posted by Ce84q8
Hello.
I had a similar problem with my carb. Check your choke thermostat. I had a broken choke thermostat and as soon as I replaced it, my high idle issue was solved. Definitely check your choke thermostat. Good luck!
Old Feb 10, 2016 | 07:37 PM
Damon's Avatar
And make sure you're even getting a full 12V to the choke through the choke heater wire (probe it while it's hooked up and running). Lots of times the choke is fine but the power wire supplying voltage to it no workie no mo.
mrestrictrplate
Dec 14, 2015 11:43 AM
defaria27
Dec 13, 2015 12:06 PM
ashleysierra96
Dec 6, 2015 12:36 PM
greasegrenade
Exterior Parts Wanted
Dec 6, 2015 10:55 AM
carattini
Dec 6, 2015 09:30 AM
