Ecu removal
Old Mar 9, 2016 | 11:57 PM
Michael Harding's Avatar
Ecu removal
Ok everyone I recently bought an 84 berlinetta with the 305. Shame about that but regardless I was wondering what the ecu actually controls and what I would have to change in order to chunk that pos into tha river. Seriously if I wanted KITT to control my car I would've bought a new camaro. I want COMPLETE control of everything. Any help is appreciated. And yes I already have a 383 on the engine stand so no need to go into the swap a 350 in it debate. But will be awhile before I can finish the engine and this car runs like @$&#!!! Idles at 530 drops to 450 try to die I have to keep hitting gas. Most times refuses to even start. On the rare and very unsatisfying occasion that it does start when I push the gas half or wot it bogs down to a stall or if I get revved up in first then it hesitates to shift. And by hesitation I mean serious hesitation where I have to let off the gas for it to shift. Thought about some c4 of some form of 50 caliber weapon would help. I won't even go into the lights acting like they're possessed by the electro gremlin god of death.
Old Mar 10, 2016 | 09:28 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Ecu removal
You can pull out the ECM / ECM Harness completely and still have all the gauges and accessories working properly. The most significant thing you will loose by removing the ECM is the automatic tranny lock-up feature and there are aftermarket kits you can buy to restore that function.
Once the ECM is gone, you'll need a vacuum advanced disributor and non-CC Carb to complete the 'conversion'.
Old Mar 10, 2016 | 01:19 PM
Re: Ecu removal
Gotcha. Thanks for the info. Can't begin to tell u the irritation I'm feeling with this car. I absolutely loved the berlinetta in the day. This "engine" is driving me nowhere but up tha wall. I want to get it in decent running condition so I can at least drive it to and from work. Gave my kid my truck so yea. Any ideas to what's going on under the hood from the description I gave?
Old Mar 10, 2016 | 02:03 PM
Re: Ecu removal
Thanks everyone. Yea this 84 is dent/rust free. Interior is amazing for the age. Couldn't pass it up for a grand. Brand new tires on,lol, Pontiac rims.
Back looks like it never saw an occupant. I'm impressed how it was kept so clean. I'm restoring it which is why I want to keep the dash original. But I won't subject anyone to a 305. Besides my boat need's a good anchor.
Old Mar 10, 2016 | 05:47 PM
DonW's Avatar
Car: 1983 Z28
Engine: Carbed 305
Re: Ecu removal
definately a survivor just needing some attention. I like it
Old Mar 10, 2016 | 05:48 PM
DonW's Avatar
Car: 1983 Z28
Engine: Carbed 305
Re: Ecu removal
Im guessing you have already done the basic tune-up stuff like plugs, wires, rotor and cap? May work wonders if you havent
Old Mar 10, 2016 | 06:46 PM
Re: Ecu removal
The humorous thing here is I have the stuff. Just haven't done it yet. Been fighting the electrical gremlin army lol. I'm going to have to replace tha light module unfortunately. Just afraid to see how much that is. But yea I was gonna do the tuneup but this Texas weather is retarded. Pray for rain he answers with a vengeance lol
Old Mar 11, 2016 | 05:43 AM
Re: Ecu removal
Never owned a berlinetta before but have owned an 86 iroc which is in the garage as well. And a 91 police interceptor with 350 and 5 speed. Now THAT was a beast. Miss that car. But looking at this berlinetta as opposed to the others I have never seen such night and day differences. Wish the made aftermarket modules and so forth. Anyone find one let me know. Thanks for the info on it everyone. I'm gonna do quite a bit on it today like 1 removing that T Rex of a catalytic converter lol.
Old Mar 11, 2016 | 07:51 AM
brettr81's Avatar
Car: 91 Firebird
Re: Ecu removal
Sounds like you have a vacuum leak.
Old Mar 11, 2016 | 07:59 AM
DonW's Avatar
Car: 1983 Z28
Engine: Carbed 305
Re: Ecu removal
Why? Can you hear it hissing? I dont hear anything lol
Old Mar 11, 2016 | 08:08 AM
brettr81's Avatar
Car: 91 Firebird
Re: Ecu removal
Sorry, my CPU fan was too high. That must have been that dang noise.
Old Mar 11, 2016 | 08:13 AM
DonW's Avatar
Car: 1983 Z28
Engine: Carbed 305
Re: Ecu removal
Old Sep 8, 2016 | 11:22 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Ecu removal
Will the AIR injection system still function if the ECM is removed?...
Old Sep 12, 2016 | 05:37 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Ecu removal
It will not function correctly, as the ECM controls the diverter valve via the feedback of the system. You can always switch to a vacuum controlled diverter valve like the earlier vehicles used that didn't run a CC-carb if need be though. Then again, the vehicle is over thirty years old, it doesn't need to pass emissions to get a sticker...
Old Feb 2, 2017 | 07:25 PM
Toxicant's Avatar
Car: 1988 Firebird Formula
Axle/Gears: 3.23 4th Gen w/ powertrax locker
Re: Ecu removal
Im just about finished doing a TPI to Carb swap and i left my ECU in place and went about just hooking all my sensors back up and for the most part haven't had any problems just abandoned it in place but i do have a 5-speed so i didn't have to deal with the tranny.
Old Feb 3, 2017 | 08:52 AM
hockeyman48's Avatar
Re: Ecu removal
More than likely your radiator fan is still being signaled/controlled by temp sensor and ecu (input/output signal). That is ,unless you installed a separate fan controller. I have converted my 84 Z-28 HO to new distributor/non cc quadrajet carb/all smog emissions removed.ECU only controls radiator fan cooling.Check engine light is on....but I use it as an indicator ECU has power to it.Probably could change nomenclature from check engine to ECU power on. LOL.
Michael Harding
Nov 10, 2020 03:54 PM
Charlie113
Mar 10, 2016 02:49 PM
b2tw45p
Mar 10, 2016 01:57 PM
David Fite
Mar 7, 2016 07:43 PM
camarokid008
Feb 29, 2016 04:19 PM
