Clogged fuel lines might cause lean condition?
Old May 19, 2016 | 08:59 PM
bubbaz28's Avatar
Car: 1983 Z-28
Engine: 305 LG4
Transmission: 5-speed
So here's where I am on trying to get my Camaro running well. It is running lean for some reason... possibly I'm not getting enough pressure or flow to the carb? A few questions-
Will replacing the fuel pump maybe help? I was under the impression these pumps don't die slowly, rather they crap out on you suddenly...
Can I blow compressed air through the lines that go to (and from) the pump? I figure that may help clear the crap out, if there is any. One troubling sign- when I replaced the filter at the carburator, it had some rust bits in it. Not good.
Is there a filter sock inlet or something of the sort I can get to that might be clogged up? If possible, I'd like to avoid dropping the tank- please let me know what you think- thanks! J-
Old May 19, 2016 | 09:37 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Clogged fuel lines might cause lean condition?
Low float level in the carb will cause a lean mixture. A vacuum leak will do the same thing.
Old May 19, 2016 | 09:54 PM
Damon's Avatar
Restrictions in the fuel system (of any description) will typically only be noticable under load. If the car takes off like crazy under WOT and then suddenly "hits a wall" that can be fuel restriction. If it's just lean when cruising at part throttle, that's NOT a fuel restriction issue.
Old May 19, 2016 | 10:04 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
stick a magnet on the bottom of the gas tank. that will help keep rust away from getting in the fuel delivery system.
Old May 20, 2016 | 03:42 PM
bubbaz28's Avatar
Car: 1983 Z-28
Engine: 305 LG4
Damon, the dang thing is the same as when you drove it. I guess I'm just stabbing in the dark about a fuel delivery problem... it doesn't die when the throttle is open, it craps out when warm and idling. I replaced the O2 sensor, cleaned and reinstalled the EGR, and I think the ECM is OK... I also don't think I have any major vacuum leaks. Recently I replaced fuel filter, plugs, wires, dist. cap. I like the magnet idea also, that would probably help a lot.
notrabies
Jul 29, 2016 09:39 PM
2kickassbirds
Apr 18, 2016 02:48 PM
Kakdiesel1
Apr 1, 2016 04:33 PM
acerulz
Carburetors
Mar 30, 2016 09:04 AM
BeyondZ28_85
Mar 16, 2016 06:34 PM
