Fuel problems
Car: 1986 IROC Z28
Engine: Carburated small block 454
Transmission: Level 3 Raptor 700R4 2600 stall
Axle/Gears: Strange S60 3:73 S Trac Posi
Re: Fuel problems
Ideally yes, it helps prevent vapor lock by circulating unused fuel back to the tank instead of sitting deadheaded in a line under the hood. I have an external electric 45 psi fuel pump, with a return style regulator under the hood; the regulator reduces the pressure to 5 psi for the Holley Carb and sends what the carb doesn't use back to the tank in a return line.
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
Re: Fuel problems
Depends on what you are using for a fuel pump. If you are using stock fuel pump components, then you will (as MSgt says above).
SpectroRacing
31
Sep 18, 2020 12:30 AM
MelodyS
Camaros Wanted
Jun 20, 2016 02:45 PM
MelodyS
Camaros Wanted
Apr 21, 2016 08:00 PM
mizz0313
Apr 12, 2016 12:51 PM
