will a bad electric choke keep my atv from starting
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: will a bad electric choke keep my atv from starting
You should go ask on an ATV forum that is dedicate to your specific vehicle
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
The "ask a question" pop-up that this site has now when you are a guest is really leading to some off-topic questions. Got it in the carb section, though!
Transmission: 4L80E/4L80E
This Board is dedicated to 3rd generation GM f-bodies, Camaro and Firebird, 1982-1992 model years.
Sorry if you were led to believe otherwise.
