Choke Wires
Old Jan 1, 2002 | 09:12 PM
Huckster's '84 TA's Avatar
Car: 1984 Pontiac Trans Am
Engine: 5.0L
Transmission: TH700-R4
Choke Wires
I have a non-CC Qjet on my 305. The choke doesn't work and i am pretty sure that it is not the actual choke on the carb. I have had several different ones one there. My question is where does the wire that is connected to the choke run too? I believe that mine got disconnected or something because if I hook it up, the choke still does not work and the choke light stays on indefinitely. Any help would be great. Thanx.
Old Jan 2, 2002 | 01:21 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The choke light should be on only when the car is stopped, and should go out when it's started. If your choke coil was disconnected or burned out, the choke light would be off at all times. You could have a blown choke heater fuse, or a bad choke heater relay.
<img src="http://members.shaw.ca/crussel/choke_wiring.gif" width=75%">
The choke light also doubles as an alternator light, but it sounds like your alternator is working ok.
InfinityShade
Feb 21, 2016 01:29 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
1985chevydude
Aug 20, 2015 12:29 AM
86IROC112
Aug 17, 2015 02:00 PM
mustangman65_79
Aug 11, 2015 03:17 PM
