throttle return spring
Old Oct 21, 2017 | 02:26 AM
79beast's Avatar
Want a title? Post!
I just installed the edlebrock 1406 on my 79 gmc k2500. I had to get an aftermarket throttle cable bracket because the stock bracket doesn't fit on the 1406. Now I'm not sure where to hook the return springs. Any suggestions? Do I need to get another bracket for the springs?
Old Nov 9, 2017 | 09:24 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: throttle return spring
The spring on my carb bracket goes from a little hole on the throttle itself to the bracket for the TV cable support on the intake manifold. You just need to have it set up so it pulls the throttle closed when you take your foot off the gas pedal.
JamesC
Carburetors
34
Jun 17, 2018 08:04 PM
Bald_eagle_machine
Oct 26, 2016 11:25 PM
Pilotrick50
Sep 26, 2016 11:03 PM
Pilotrick50
Sep 26, 2016 11:02 PM
91dime
Sep 17, 2016 12:07 AM
