In tank fuel pump sending unit
Old Feb 28, 2018 | 02:10 PM
Manic Z's Avatar
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
Hey guys. I keep killing my external electric fuel pump, and have decided to go with an electric in-tank pump.
Questions:
Are the fuel tanks all the same from every year?
What sending unit/pick up would I need? My car is a Canadian car and has no computer.
What fuel pump would be recommended to keep up with a 435 hp Qjet car?
Old Apr 12, 2018 | 06:19 PM
tater's Avatar
Car: Dad's 87 Bird (Org Owner)
Engine: Vortec 350 Crate Motor
Transmission: TH350
Axle/Gears: 3.42 Posi
Re: In tank fuel pump sending unit
Why do you keep going through external fuel pumps?
I have used a Holley "RED" electric fuel pump for 8 years without a single problem. I use the "RED" pump because it is regulated to 5-7 psi right out of the pump. No need for an extra external fuel pressure regulator.
Old Apr 12, 2018 | 07:59 PM
NoEmissions84TA's Avatar
Carter M6626 block mounted mechanical. Less than $20.00
Old Apr 25, 2018 | 11:35 AM
83 Gman's Avatar
I agree with this.
"External pumps don't last". What's the problem ? Do you have a filter in front of the pump first ? Is there junk inside the failed pump to show signs of crap from the tank ?
Why make life more difficult with an in tank pump ?
Old Apr 25, 2018 | 11:59 AM
Manic Z's Avatar
I never ran a pre filter.....I just finished installing a pre filter with a Walbro external. Let's see how it goes this time.
I also wonder if my ground is good enough.
Thoughts on running a ground wire right to the battery instead of a chassis ground?
Old Apr 25, 2018 | 12:10 PM
83 Gman's Avatar
As far as the ground. If all your body/engine grounds are in place, just make sure the ground to the pump is clean and protected from weather. No need to go to battery.
What model Walbro pump ?
If you want to go one step further, you can always add a relay to operate the pump.
Old Apr 25, 2018 | 12:51 PM
Manic Z's Avatar
This one from Holley (it's a relabeled Walbro)
https://www.holley.com/products/fuel...s/parts/12-927
Hopefully it supplies enough fuel.
If not, I might try a Walbro 255 and see if my regulator will dial the pressure down...
Old Apr 25, 2018 | 02:30 PM
83 Gman's Avatar
That pump makes more pressure than a Q-Jet can handle. You will need a pressure regulator with it. Carbs only take maximum 7 psi to them. Find out if that pump has an internal relief, as too much back pressure can cause it to burn out/overheat.
It does look like a straight up vane pump. A Holley pump is a vane style but has a relief in it.
Here's one using no regulator. Also look on different sites for a lower price.
https://www.holley.com/products/fuel...parts/12-801-1
Firebat
Jul 28, 2011 11:38 PM
Dante93GTZ
Mar 12, 2011 04:29 PM
Polo-94Z28
May 15, 2007 10:27 AM
