Ccc Q-jet to edelbrock wire connections
Old Jul 8, 2018 | 07:07 PM
Rich1374670x's Avatar
I have giving up on the q-jets and thought I would try a 1406 edelbrock carb. This is a non egr carb I had lying around and thought I would put it on the t.a. I have a some questions.
1. What do I do with the 3 electrical connectors, including the one on the throttle linkage? Just leave them unplugged?
2. Ok to just plug off the egr with a plate and gasket? Any other areas that should be plugged from the egr?
3. Any choke or check engine lights that will remain on?
4. Is this bent?
3.
Old Jul 8, 2018 | 11:37 PM
NoEmissions84TA's Avatar
Re: Ccc Q-jet to edelbrock wire connections
No, not bent.
Your CCC QJet was computer controlled, along with your distributor.
You can't just swap to a manual carb and everything else keeps working.
Read this: https://www.thirdgen.org/carbswap/
Old Jul 9, 2018 | 05:39 AM
Does the non computer controlled distributor connect right in? Do wire connections need to be altered?
Old Jul 9, 2018 | 10:08 PM
A non computer controlled distributor is a direct drop in.
And it will plug in to the wiring also.
But by not using the ECM you will lose the TCC torque converter lockup function at the very least.
To go this route, you basically have to set you car up the same way as the Canadian export cars. Those used manual Quadrajets, manual distributors, and you should follow their emission diagrams to maintain proper fuel tank venting.
Old Jul 9, 2018 | 10:09 PM
It's a manual car.
ZedorZee?
Carburetors
16
Jan 17, 2010 06:04 PM
85irocr
Carburetors
Nov 6, 2009 10:09 PM
Randy82WS7
Jan 19, 2006 02:12 PM
Momar
Carburetors
Feb 21, 2003 07:27 PM
