Computer Q jet lean?
Old Jul 21, 2018 | 07:37 AM
lugnut's Avatar
Car: 1970 chevelle
Engine: Lq4 408
Transmission: th400
Axle/Gears: 3:73
Hello,I finally got my new engine running in my 84 z 305. A couple things,the fans come on about 180 no tune all stock also exhaust seems to b pretty hot shot a thermal gun to them and aboit 400 deg seems warm to me
I did rebuild q jet I know they r CC but u do have to adjust mettering rods, maybe I have them to far in didnt c much in the instructions on how many turns and no I didnt count them when I took it apart my bad
Going to pull a plug and look and ideas on the carb adj thanks
Old Aug 10, 2018 | 05:21 AM
lugnut's Avatar
Car: 1970 chevelle
Engine: Lq4 408
Transmission: th400
Axle/Gears: 3:73
Re: Computer Q jet lean?
Yea thanks for all the replies
Old Aug 10, 2018 | 06:08 AM
Saxondale's Avatar
Car: 84 Z
Just difficult to read the first post. The words blend together without punctuation or words spelled out. But yes easier to write on a mobile phone.
I too was hoping for a reply to see if the 400 degree exhaust temperature indicated anything.
Old Aug 10, 2018 | 06:40 AM
BigDogBob's Avatar
Car: 86 Trans Am
Engine: Carb'd LM7
Transmission: TH400
Axle/Gears: Stock 2.73
You can't get upset that you don't get replies when you're not asking a coherent question.
Try again.
Old Aug 12, 2018 | 11:08 PM
zed-028's Avatar
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
It's hard to even find a question in that garbled mess...
Old Aug 13, 2018 | 06:55 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
you took the carb apart and put it back together without taking the time or care to reset the rich and lean stops. we have to also question the integrity of the rest of the job. you also probably made no attempt to adjust the idle air bleed for proper dwell or set the TPS.
the next step would be me spending a lot of time explaining how to properly set the carb up and make all of the checks of the system and adjustments needed to get it running like new. this would likely take several posts back and forth.
then you'd come back finally and tell us that your problem was something else entirely and after you cut the wires to (fill in the blank) or replaced (fill in the blank) with something totally unsuited as a replacement for (fill in the blank); that the car was now running great (and you really don't notice the smell of the exhaust and are super happy to finally get slightly above 10 miles per gallon).
i'm not sure i have the energy for all that anymore so maybe you should just continue with the random fastener removal and re-install until the bulk of the vehicle returns to its natural state.
but if you really want help let me know.
GWW
Jul 28, 2007 05:57 PM
86IROCTHD
May 19, 2005 10:44 PM
DrekkenX
Feb 9, 2003 02:29 PM
Craig Moates
23
Feb 20, 2002 03:56 PM
