82 Berlinetta won't keep idle when hot
Old Aug 26, 2018 | 05:04 PM
berlinetta9's Avatar
I've got an 82 Berlinetta that has recently been acting up. It dies immediately after starting the engine when it's hot. I have replaced the fuel pump but this did not fix the problem. Also, the engine occasionally bucks/misfires when I kill the ignition after driving it. Could this be a carburetor/ gas-fuel mixture problem? Opinions are greatly appreciated.
Old Aug 26, 2018 | 06:57 PM
zed-028's Avatar
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
Re: 82 Berlinetta won't keep idle when hot
The bucking and carrying on after powering off is usually high idle setting related. People usually misdiagnose it as a timing issue, however with the ignition off, timing no longer plays part in it. Is this a quadrajet or a holley carb?
Old Aug 29, 2018 | 10:13 AM
It is a 4 barrel quadrajet.
Old Sep 9, 2018 | 02:32 AM
GM B-body's Avatar
Car: 1986 CHEVROLET
Engine: 5.0L 305
OEM electronic Quadrajet?
Old Sep 9, 2018 | 07:52 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
next time it acts up when hot, ensure that the choke plate is completely open-straight up. check for fuel in the bowl by manually engaging the linkage and looking for the squirt of fuel into the primary throat. if it's flooding, the qjet throttle needs to be held full open (pedal to the floor) while cranking to clear a flood.
if you have not replaced the distributor a new one is a good idea. inexpensive and will come with a new ICM and pick up coil, both items that like to fail when hot. on top of that the normal tune up items, plugs, wires, cap and rotor.
we can walk you through a thorough diagnostic for the carb and associated stuff if you're ready.
Jackmino
Jul 15, 2017 05:14 PM
samiam91RS
Oct 12, 2014 08:30 PM
Lestrey08
Jul 1, 2009 05:00 PM
bigjeepinyj
Oct 14, 2002 02:51 PM
