Keep cc carb or swap to edlebrock
Old Sep 18, 2020 | 04:27 PM
midge54's Avatar
Car: 86 Trans am
Engine: LG4
Axle/Gears: 3.27 9 bolt posi
I have an 86 trans am with the original lg4. Since its been pretty much unmolested its entire life i was thinking of keeping it almost completely factory, it only has 102,000 miles on it. Problem is the car idles like crap. It sounds like it has a hellish cam in it and will pop in the exhaust when idling. Once your give it gas though it runs like a champ and is even drivable. Im tossed whether to pull the carb and try to find someone local who can rebuild and set it up for me or i have an edlebrock 1406 and a vaccuum advance distributor laying around which are both new. I dont want to lose too much originality of the car but finding people to work on cc carbs is getting harder and harder.
Old Sep 18, 2020 | 04:37 PM
NoEmissions84TA's Avatar
Re: Keep cc carb or swap to edlebrock
Give Cliff a call: https://cliffshighperformance.com/
I am assuming that you already correctly determined that this actually a CC carb problem and not something else.
Old Sep 19, 2020 | 09:36 AM
Even if you decide to swap carbs, I would suggest that it NOT be an Edelbrock.
Look at this one instead. https://www.summitracing.com/parts/hly-0-6210 will run better, get better gas mileage, and above all, FIT THE CAR, which an Edelbrock doesn't. You can get them used, refurbed, and so forth, as well.
Old Sep 19, 2020 | 08:48 PM
midge54's Avatar
Car: 86 Trans am
Engine: LG4
I actually think i have a 1405 not 1406 edlebrock. Ill have to checkthe number on the side tomorrow
Old Sep 19, 2020 | 09:11 PM
Not a big difference.
The 1405 is non-emissions calibrated.
The 1406 is emissions calibrated.
Just a small difference in the rods & jets, IIRC.
Old Sep 19, 2020 | 11:21 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
1405 is manual choke. 1406 has electric choke. Both are 600 cfm...
Old Sep 21, 2020 | 12:21 AM
vorteciroc's Avatar
Top Answer: 1
The electric choke models are most always calibrated for a leaner air/ fuel mixture compared to the manual choke models.
Old Sep 22, 2020 | 03:10 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
This is correct. Don't worry about how it comes pre-calibrated because the right thing to do is calibrate it for your engine. My Edebrock 1406 ran decent out of the box but ran great when I tuned it properly.
However, I recommend you keep your CC carb and fix it right. I am happy with my Edelbrock, but if it still had the original CC carb I would leave it alone I think (previous owner removed it).
Old Sep 24, 2020 | 10:53 AM
midge54's Avatar
Car: 86 Trans am
Engine: LG4
I called cliff, great guy. He said he really didnt want to mess with mine being that its computer controlled. He was able to tell me exactly whats wrong with it based off what i told him it was doing and he suggested giving TTA performance a call since theyve done the cc quadrajets in the past. So im going to call them today and see how much it will cost to have mine done
Old Feb 7, 2021 | 07:53 PM
86Lucille's Avatar
Are you sure it’s not a vacuum leak? The CCC Quadrajet rebuild kits are at NAPA. They’re pretty easy to rebuild, probably $50 too. I rebuilt mine a couple years ago. Ran fine until it flooded. The needle was upside down, so I flipped it over and it ran fine after that.
rockett3s
Carburetors
Sep 16, 2013 09:49 AM
87CamaroMan
Carburetors
Feb 28, 2006 01:15 PM
Darkhawks86T/A
Carburetors
Aug 23, 2002 04:54 AM
daniel dekay
Carburetors
Apr 16, 2001 12:10 PM
