Lost Initial Cold Start Fast Idle (first time)
Car: 1986 Trans Am
Engine: 5.0 LG4 4BBL
Transmission: T5 5-Speed
Morning guys,
Out of the blue, I seem to have lost initial cold start fast idle this morning. I hit the throttle once before start-up as I do every morning, engine started within 3 second as usual, BUT idled immediately at 800 steady instead of the usual 13-1400 it always does when cold.
It crossed my mind to not drive it since it was still dark but I let it idle for 2 min then drove away, perfectly normal the whole 8 mile drive to work. No hesitation, no weird smells or sounds even on the highway.
I had the factory Q-jet rebuilt 2 months ago and after some initial tuning its been solid ever since.
Any initial thoughts before I take a look at it this afternoon?
Thank you everyone.
Thank you everyone.
Re: Lost Initial Cold Start Fast Idle (first time)
Try a shot of spray silicone lube on the fast idle linkage all over the carb. Hold the throttle open a bit with one hand and work all the links with the other, see if anything binds.
Not rocket science here, it's just a carb.
Car: 1986 Trans Am
