Carb heat soak solution
Car: 86 Pontiac firebird base
Engine: Lg4 305
I recently went to the Syracuse nationals and found a small vendor named CoolCarb selling ~.25” composite spacers. Pretty sure it’s an aluminum coating around some kind of poly. I bought a heat plate, spacer, gaskets and hardware for 80 bucks. With a 2 hour install the plates alone managed to decrease the heat soak to the carb so much that I could rest my hand on the carb indefinitely after 20 min of operating temp, on my car around 220 degrees. Noticeable power gain. Ive got an 86 firebird lg4, Holley street dominator spreadbore intake, edelbrock 1406. Also saved me about .5” from deleting the previous aluminum adapter. Highly recommend and well worth the money, with a variety of different styles for qj, squarebore, etc. figured this could help someone out there.
(not sure if this is in the right thread or not)
Car: 1985 Firebird & 1992 Camaro B4C 1LE
Engine: 310 LS1. & 305
Transmission: TH350 & T5
Axle/Gears: 9" 3.73
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Carb heat soak solution
Running a composite spacer is a great plan. I even use one under my sniper unit. The difference in heat transfer is crazy
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Blocking off the exhaust crossovers in the intake manifold also helps...
