Switching to Carb another question?
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Well I am still looking into what carb I would like to get. I have a good friend who does a lot of drag racing and he said I need the Holley 4160 750 cfm. That one sounds good however what is the thought on The HOLLEY STREET AVENGER 770cfm would that be too much? Or how about an Edelbrock? 750 with an electric choke? My sig will tell you what I have.
Thanks for the opinions
Brian Felts
Brian Felts
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
I like my Edel 750. It is the first carb I've owned. I can tell you though, that Holley beat Edelbrock in a poll on the board a while back. The next time I get a carb, I believe I am going to get a Speed Demon or Holley just to see what the difference is.
Transmission: 4L80E/4L80E
Forget the Avenger. Too much buck for too little bang. Get the 4160 electric choke model along with jet kit, quick-change secondary spring kit, secondary spring assortment, 4150 secondary conversion kit (that's what the carb on the 396 in my sig is), and you'll have an Avenger for less money. The extra 20 CFM they claim is moot.
A Demon makes even more sense. More money, but you get more with it. Including a wet-tested flow rating (means more flow for the same CFM rating). Wish that's what I would have done instead of the Holley.
Originally posted by five7kid
[BThe extra 20 CFM they claim is moot.
A Demon makes even more sense. More money, but you get more with it. Including a wet-tested flow rating (means more flow for the same CFM rating). Wish that's what I would have done instead of the Holley. [/B]
Okay, I came close to contradicting myself.
The big diff is that the Demon is more likely to work out of the box than a Holley. And, Demons tend to put out more ponies than the same rated size Holley. But, you aren't likely to get the same boost from Holley 4160-type 750 CFM and Holley Avenger 770 CFM - That's the point I was trying to make.
hehehe just check'n
My jury is still out on the Demon over a holley tho. I have my doubts about thier really being any better. I'm using a Demon on my current project I'm doing for a friend. Hopefully in a few weeks I'll have a better formed opinion on that.
86IROC112
Aug 17, 2015 02:00 PM
