Anyone Used The New Holley Street Avenger Carb??
Old Feb 27, 2002 | 03:06 PM
2ponchos's Avatar
thinking bout using one of the new street avenger carbs they have out.. i am new to carbs. but to me it looks like a nice setup does anyone have any input?? thanks
Attached Thumbnails Anyone Used The New Holley Street Avenger Carb??-firebird_0004.jpg
Old Feb 27, 2002 | 04:05 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
I used the S/A 770 on my combo and it works nice. It did take a little tuning out of the box however I would buy it again. any questions just ask.
Brian
Old Feb 27, 2002 | 04:21 PM
2ponchos's Avatar
well here is the setup that its going on.. 406 short block its has forged pistions.. vortec heads and the edelbrock intake that uses the vortec heads.. the block has no miles on it its been machined and the good stuff. the guy didnt know exactly what cam is in it..he said that its 3 steps over stock whatever that means.. and then i plan on running the 670 street avenger cam.. i have hooker headers and hooker cat back system.. what kindof horsepower can i see out of this setup and what kindof 1/4 mile times?? and what kindof tuning did u have to do to get it to work??? just so i know?? thanks!!!!!
Old Feb 27, 2002 | 05:49 PM
Well the cam info is kinda needed to make a guess. I have a 350 with Vortec heads LT-4 cam and use the 770. The tuning well I went with a lighter secondary spring........used the Vac guage and tuned the idle air mixture.........and I think the rear float is a little high so I will have to lower that. Not knowing the cam I would guess with a good tune you can make 350+ hp but I think I would use the 770 cfm.
Brian
Old Feb 27, 2002 | 05:57 PM
Dragula's Avatar
I bought the 770 for my 383 I am building. I am sorta new to carbs also. There are several people who will tell you to get the regular carb, and then buy the stuff to upgrade it to the same thing as the Avengers only cheaper. Thats a good way to do it if you know more about carbs. I have always done TPI stuff and this is my first carbed engine so I spent the extra money to get the avenger. Besides, I read in Chevy High Performance that they have a newer design to the metering blocks. I guess thats good. Either way, get the Avenger, but I would probably get the 770. The 670 would be good if you never want to run higher RPM's. Hhhuuuummmmmmmm....several people have said get the 770
Old Feb 27, 2002 | 09:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I considered the SA, chose the regular VS 750 for the reasons stated above. I hadn't touched a Holley for two decades (and I didn't really know much about them when I last had one in the late 70's), the conversion to 4150 and quick-change secondary spring setup helped familiarize me with the beast. I'm also cheap; got a full set of jets, a Holley tuning book when I got the carb, saved enough over the SA to pay for 2 test & tune sessions at Bandimere.
Old Feb 27, 2002 | 10:13 PM
EvilCartman's Avatar
Car: '82 Z28
I'm running a SA 670 on my 305.. been good to me so far and easy to tune First time firing it up though, the needle and seat were stuck or something and fuel shot out the vent up onto the underside of the hood.
Old Feb 28, 2002 | 12:59 AM
2ponchos's Avatar
well it looks like the 770 then!! i will try to get some specs on the cam but 350hp sounds very nice to me!!! sounds like a 12 sec car to me!! and that is what i am looking for thanks guys for your help!!!
Old Feb 28, 2002 | 09:28 AM
12 second if you can hook it up............but if not lots of smoke and 13's tend to keep mustangs away also........... Please let us know how it comes out.
Brian
Old Feb 28, 2002 | 01:50 PM
2ponchos's Avatar
well with my new spohn suspension stuff that i just got and my sportsman pro tires i should have any problem hooking up i hope!!!
Old Feb 28, 2002 | 02:20 PM
Thats what I used (Spohn) I still need the LCA relocation brackets from there I lowered my car 1" I think you will lay down some good time. Pleas post them so we can see how you are doing.
Brian
Old Mar 1, 2002 | 06:14 PM
Stroked-Z's Avatar
I used the 770cfm last summer on my 383. Good carb, looks good too and very good out of the box.
I am switching to a 750 dbl pumper that i had earlier on last year before the S/A though. The S/A gave me better response & seemed to improve the low-end a bit. I think i lost in the top-end though.
We'll see this yr.
Old Mar 2, 2002 | 02:43 PM
fordcrusher's Avatar
I just ran a post a couple days ago about this same thing and I changed my mind about the 670 for my zz4 and went with the 770. I get it in a week or so. I started doing research on carbs and how the cfm rating has more to do with cams and flow than just the engine size. That's to say that some 350's could run lean or rich with an identically tuned s/a 670, and others would run well with a 770, while others might just drown. I paid a mere 325 w/ shipping brand new so don't go buying it out of jegs. There was a dealership on ebay, write me if you need info on them stuck_in_toledo@yahoo.com
I won't have it in until this spring. I'm also attempting to rebuild my wc t-5, change the rear and do a interior swap, so it should be a busy but rewarding spring.
Old Mar 2, 2002 | 03:21 PM
That is true.........My 770 is running pretty rich for now. I will have to step it down a jet or two to get the tuning just right with the help of my A/F gauge. But I do love the carb.
Brian
Old Mar 3, 2002 | 03:02 PM
88'camaro305TBI's Avatar
Car: 88 IROC
Transmission: auto
2ponchos, its funny how when i got my 406, the guy i got it from said that the cam is 3 steps over stock also, and i still don't know what that means. He didn't know the numbers on the cam. I can tell you that is has tons of low end power, and is good to about 5,000 rpm, which seems like a good setup for vortec heads which have pull in studs. My 406 runs really good with the 750 holley on it, so the 770 would definitely be the right choice for you. By the way, does anybody know what 3 steps over stock camshaft means?
Old Mar 8, 2002 | 10:43 PM
85 Berl's Avatar
3 steps over stock is slightly smaller than a 3/4 race cam.
Old Mar 9, 2002 | 03:03 AM
ThirdGenFire's Avatar
Car: 2000 Trans Am and a 85 Iroc-Z
Engine: The Mighty LS1& 305 just beat meTPI
Transmission: 4L60E and 700R4
I too am new to carbs, just from TBI. I am putting a 770CFM Street Avenger on my 383 I am getting built right now. I don't know much about carbs if any and so I just bought it, then after I bought it my dad told me he could have built it to the same specs for me DOPE. Anyway if you can hookup then 12's easy no sweat. As for me I am hoping for at least 11's or something else.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
rjcme
Sep 5, 2015 01:23 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
