Really simple question
Old Feb 28, 2002 | 01:00 AM
poncho9789's Avatar
I haven't gotten a carb yet I have a friend that is giving me a 750 double pumper and a 650 vac seciondary carbs. I was wondering if the double pumper has jets in the main and seciondary. I was told that the fuel for the seciondarys were controlled by a metering block. If that is true how do you adjust the fuel to the seciondarys?
Sorry I know nothing about carbs but I am really wanting to learn.
Old Feb 28, 2002 | 08:13 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
It is possible that the secondaries have a metering "plate", which has fixed size passages and can only be "adjusted" by replacing the plate. Most DP's, though, have a metering "block", which has removable jets that can be changed to tune the mixture.
Look between the main body and the float bowl - is the piece between them about the same thickness on the secondary side as the primary side? If so, it's a metering block, with replaceable jets.
Old Feb 28, 2002 | 07:49 PM
poncho9789's Avatar
Thanks 57kid I thank you for your quick responce. I am having a hard time choseing a carb. I have a choice of a 850 dp for $175, 750 dp for free, 750 vac seciondary $50, 650 vacuum sec for free.
so many choices!!!!! I am leaning more twords the 850 dp or the 750 dp.
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
camaroken83
Aug 10, 2015 11:35 AM
