Holley Street Avenger carb
I was thinking about purchasing a new carb for me car, and i see holleys got the new street avenger out. I was just wondering is anyone has one of these on their car, and if their happy with it or what. Thanks fellas. Brandon
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Welcome aboard.
About five topics below yours is this thread https://www.thirdgen.org/techbb2/sho...threadid=87906 . It has the pros and a couple of cons on those carbs. See if the info there answers your questions, if not, come on back and reply to this thread.
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
Instead of buying a street avenger just buy a "regular" Holley with electric choke(if u need it), quick spring change kit for the secondaries then buy the metering block (remove metering plate) you'll save about 80 bucks.
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
I have the S/A 770 and love it. I run it on a miled to strong 350 with a lt4 cam. It is easy to adjust and is fairly out of the box set.
Brian
Brian
Hotrodboba400
12-10-2019 07:07 PM
86CamaroDan
09-29-2015 10:08 PM
