my car boggs when cold and warm, started suddenly.
i have a '75 350 in my carmaro, and i rebuilt the carb, it was working good but today i started it and when i step on it in all rpm ranges it boggs. it doesn't go and then bogg it just boggs.
if i hit it to hard off the line it will stall out.
my timing is at 13 degrees btc. seems to be the best place for it. tell me if i am wrong
Bidn't mention your carb type but.... accelerator pump is screwed up probably. Look down the primary venturis (engine off). Open the throttle quickly by hand. you should see two little streams of gas shoot out and actually spray onto the little booster venturis. If you don't see the streams or they are weak or broken you've got your culprit.
94 Firebird Formula M6- No options but Z rated tires. No mods over $10. 13.5@105.
79 Malibu "beater" w/junkyard 400 SBC, tweaked QJet 4bbl, finally a decent set of heads, a few other tricks. A maddening 13.000001 @ 108 on the motor with little traction. No nitrous runs with the new heads yet.
Grandma's old 78 Malibu (33K miles!) soon to have the powertrain from the 79 put in it.
"One of the last remaining QJet tuners on Planet Earth!"
db057
Aug 11, 2015 10:11 PM
