O2 sensor to tune Holley? Any kind?
Old Sep 28, 2000 | 11:08 PM
James406Camaro's Avatar
I have a 780cfm holley 3310 with the choke horn removed. It runs great with the stock jetting/power valves (72 jet 10.5 pv front 76 jet 8.5 pv rear) but I don't like the idea of the power valve in the back and the tail pipe seems really sooty.
I've heard you can tune with a voltage meter and an O2 sensor. For what year vehicle should I get the sensor to fit. I was told by a salesman at the local parts store that there are several different part numbers that give different readings for different manufactures. Is this true?
Once I get the sensor what voltage readings I'm I going to be looking for, 12-13 to 1?
James
85 camaro, 406 sbc, 5.7 rods, Sportsman II heads, Edel. Performer RPM intake, Isky 270 221@.050 .465lift 108sep, Crane Rollers 1.5 7/16, SLP 13/4 headers, TH-350, TCI Breakaway, MSD Pro-Billet distributor, AIS Ram Air Box, 295BFG's on Convo Pros @ rear
Old Sep 28, 2000 | 11:12 PM
Jester's Avatar
Get a sensor for a stock late 80's fuel injected f body. You'll also need to get a bung welded onto your headers to screw it in to.
Then, you can use a voltmeter, but I stringly suggest you get a real A/F ratio gauge. They only run about $30 and come in very handy.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
Jesters's Page of Sick Pleasure
Florida Thirdgenners Message Board
ICON Motorsports
Old Sep 28, 2000 | 11:25 PM
My SLP's have the bung for the sensor. Where can I find a gauge that cheap? Thanks for the reply.
Old Sep 28, 2000 | 11:41 PM
Jester's Avatar
Well..the bung will make it easy then
Cyberdyne makes the gauge I have..you can get it though either summit or jegs. Has a bargraph readout, uses a stock O2 sensor..works great.
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
nuggie
Aug 25, 2015 01:27 PM
soarestransam
Aug 24, 2015 08:15 AM
theurge
Aug 21, 2015 12:46 PM
