Will Q-Jet Work witht his setup
Old Oct 12, 2000 | 10:51 AM
84FBODY's Avatar
Howdy all. Was wondering if my stock Q-jet will work with this setup.
355 78cc heads domed pistons making 9.5:1 compression, Weiand stealth intake, (port matched to heads) Stock manifolds (for now) dynomax high flow cat and dynomax cat-back
John Chamberlain
1984 Sport Coupe Camaro, 1979 350. Dynomax 2 3/4" cat back single in dual out muffler. Saving for Headers, Heads, And new Intake. Then.... PAINT
The Allmighty Warrior Court Jester of The Not-So-Famous Cascade Crew
[This message has been edited by 84FBODY (edited October 17, 2000).]
Old Oct 12, 2000 | 12:43 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It would work except that the q-jet won't bolt directly to the Stealth since it has a square-bore mount, and the Stealth requires an aggressive cam (which you didn't specify), and headers which you aren't doing yet.
You'd probably be better off with a Performer RPM spreadbore.
I believe your heads would have 76cc chambers, unless they've been modified.
82 Berlinetta, orig V-6 car. Rescued w/86 LG4/TH700R with all harnesses, sensors, ECM, etc. 2.73 open. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, exhaust, paint, etc.).
57 Bel Air, my 1st car. Currently 396 .030 over, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Oct 12, 2000 | 03:31 PM
84FBODY's Avatar
My bad. Yeah 76CC. Not sure on cam I still haven't decided. As far as the q-jet bolting up that's easy enough. an adapter plate is only like 20 bucks. Headers will come but prolly a few months after the engine's together. I have a wedding to save for in April so I can't do EVERYTHING I wanted to do. Anyway thanks for the info. I basically wanted to know if it would feed it or not. Thanks again
John Chamberlain
[This message has been edited by 84FBODY (edited October 12, 2000).]
Terrell351
Jun 13, 2021 01:13 PM
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
Street Lethal
Aug 13, 2015 08:28 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
