Fuel pump or carb problem?
Old Oct 31, 2000 | 01:30 PM
Trnsam87's Avatar
Im hoping someone might be able to help.I Have a holley 750 vac sec. im running on my 350.When i start the car it will run normal for about 10 seconds, then all of the sudden the cars idle will drop and cut off.If i try to gas the pedal i can keep it alive barely, but it shakes the whole car and runs real rough, but once i left of the gas it dies again.I have the idle set at about 800rpm.I checked the plugs and i believe my timing and vacuums are ok.The fuel pump is pretty new, but can it have gone defective?I have a fuel (psi)gauge on it, and when the car starts to die, the fuel gauge drops.Any thoughts would be appreciated, Thanks in advance. ~~Jaime~~
1987 TransAm
350 sbc
Holley 750 Vac sec
Edelbrock Performer Rpm Heads/Intake/Cam
Flowtech Ceramic Headers
Crane Roller tip Rockers/pushrods
Flowmaster Muffler
Old Oct 31, 2000 | 01:51 PM
Cosmik Debris's Avatar
The first thing to check would be the float level.
Cosmik Debris
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
