Hey Jester, can you help me out?
Subscribe
Oct 27, 2000 | 04:38 AM
Hey, I don't know if your the same guy from the old days, Jester92RS (I think), but I know you did that carb swap and I was wondering how did u figure out what kind of throttle cable bracket you needed for your carb swap? So far I am unsure on what kind to get. I looked through Summit and Jegs and I can't figure out how to determine what will work with my setup. I am using the ZZ4 with the GM Aluminum Dual Plane manifold that comes with it, part number 10185063 (if that helps) Do u have any idea? Oh and I am using the Speed Demon 750cfm secondary carb. Know of anything about throttle cable brackets that will work with me here? Thanks. And is there anything else that I should expect to be a problem? Thanks.
Eric Natzke
91 Firebird 305 TBI (ZZ4 summer of "01")
ASCD Ram Air Hood-3" custom exaust-Flowmaster 80 Series-No Cat-Edelbrock TES Headers (coated)-March Pulleys-TBI Spacer-K&N Open ELement-TransGo Shift Kit-B&M Supercooler 28,000 GVW-Hypertech Thermomaster-160 Stat-3:42 GM Gears-Auburn Posi Unit-Edlebrock Strut Tower Brace-MSD Superconducters-Accel Cap & Rotor
-Rapidfire Plugs-265/50/R15 Tires-Emmison's all Gone
http://hometown.aol.com/J007Golden/index2.html
Reply 0
Oct 27, 2000 | 05:48 PM
not sure if it helps much, but i went from a TBI and trashed that bracket and bought one at a local store. Adjustable and had the TV/Trans cable bracket on it... So far, it works for both my Holley AND my Edelbrock...
Hope this helps...
[This message has been edited by Duffster (edited October 27, 2000).]
Reply 0
Oct 27, 2000 | 06:44 PM
I used the stock throttle bracket. I had to elongate one hole to get it to bolt to my intake, but it did. Then I used 2 short pieces of sheet metal with bolts in each end to extend the cables enough to reach the carb.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
Jesters's Page of Sick Pleasure
Florida Thirdgenners Message Board
ICON Motorsports
Reply 0
Oct 27, 2000 | 08:28 PM
Thanks guys, I will try these out.
Eric Natzke
Reply 0
Oct 31, 2000 | 01:09 PM
Holley makes a bracket for use with 700 r4's.That what Im using.
Reply 0
Oct 31, 2000 | 01:16 PM
Would the holley bracket work with a Demon carb though?
Eric Natzke
http://members.aol.com/j007golden/91firebird.html
Reply 0
Oct 31, 2000 | 02:59 PM
I would need to see the rear left part of the base plate before I could answer that.If I have a chance I will take a pic of mine later.
Reply 0
Oct 31, 2000 | 03:02 PM
Ok, thanks man
Reply 0
Subscribe
