vacuum advance distributer with the computer controlled quadrajet?
Subscribe
Nov 3, 2000 | 08:48 PM
I just finished installing my new crate 350 and am using the quadrajet from the 305. It is computer controlled but the distributer on the 350 is vacuum advance. I hooked up a vacuum from the carb and it seems to work just fine except it idles like hell. It idles fine but very rough. Also, it wonlt idle on its own when I first start if for about 3 seconds and then it is fine. It has consistantly behaved in this manner since the engine went in. Any advise?
Reply 0
Nov 4, 2000 | 07:50 AM
Sure I have some advice get a non computer controlled carb...those suck. I dunno enough about Q junks to answer your ? though..sorry.
Reply 0
Nov 4, 2000 | 08:36 AM
Even better would be to pull the distributor that came with the crate engine and install the computer controlled distributor from the 305. Then everything will work and you won't have to buy an expensive carb.
82 Berlinetta, orig V-6 car. Rescued w/86 LG4/TH700R with all harnesses, sensors, ECM, etc. 2.73 open. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, exhaust, paint, etc.).
57 Bel Air, my 1st car. Currently 396 .030 over, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Reply 0
Nov 4, 2000 | 10:15 AM
The reason why your car doesn't idle right is because the primary rods are held in the "up" (rich) mode all the time. This is because you disconnected the distributor, hence the computer cannot control the carb (mixture control solenoid) or dist., so it ramains in constant open loop. Either put in the computer controlled distributor, as five7kid mentioned, or get a non-computer controlled carb, like Jester mentioned. But you can't "mix-and-match" non-comp. parts and comp. parts
George P. Lara
1994 Z28 LT1 T56
1984 Z28 High Output
Member: SCCA, SCFB, SC3GFB
Reply 0
Nov 7, 2000 | 09:13 AM
George is right. The CC Qjet's default is FULL-RICH from idle right on up if it's not hooked up to a correctly fuctioning ECM.
Reply 0
Nov 8, 2000 | 02:32 PM
The idle circuit in an unconnected computer-controlled Q-Jet can be adjusted, but outside of that it'll run too rich. I'm a big believer in junkyards. Try to find a good Q-Jet and then scrounge around to collect rods, jets, hangers, etc. from other Q-Jets. Clean it up and start experimenting with your metering rod collection until you get a good combination. Stuff your pockets with HEI springs and weights while you're there, too! ;-)
Reply 0
Subscribe
